Question about Dell Computers & Internet
How can i change the driver of my monitor so that it is no longer seen as generic pnp monitor?
    New Friend:
    Problem Solver:
  • 19 Answers
Go into your device manager in control panal and add a new monitor or go into the monitor in there and install new driver
Posted on Nov 23, 2014
rey jr
  • 149 Answers
SOURCE: Generic PnP Monitor to LCD Monitor LG L1719S
hi there, just download the driver software. ty
Posted on Jan 01, 2008
  • 3940 Answers
SOURCE: blurred pictures on monitor
The problem is not the monitor, it is the display adapter (Video card) of your system needs a valid Vista driver. (NVidia, ATI and Intel are the 3 largest Graphic card manufacturers) Monitor drivers are almost never needed except on some advanced large LCDs.
You said up upgraded to Vista, did you use a Vista upgrade DVD or just perform a clean installation of Vista? Have you installed Vista Chipset drivers? The chipset and Graphics drivres may not be native to Vista, you may need to install them.
Posted on Jul 05, 2008
pravinbhavsa
  • 348 Answers
SOURCE: benq G900W Monitor: Settings show as generic non-PnP monitor and
for that purpose you have to insert an AGP card into AGP slot of grade 8X then you can see full resolution because the inbuilt display card does not support to high resolution
Posted on Mar 05, 2010
  • 33 Answers
SOURCE: have just upgraded to windows 7 and my Viewsonic
In most cases you don't need the drivers for a monitor to work completely fine. In order to obtain your drivers you can always check the manufacturers website and they should have drivers listed, in your case they do. Although I couldn't locate VX715 i found many VX models in the driver search. There should be one that works fine, just make sure you download the right right IE: windows 7 x32/86 if your running a 32-bit operating system, or windows 7 x64 if you are running a 64 bit operating system. Here is the website I located http://www.viewsonic.com/support/downloads/drivers/
Posted on Jan 09, 2011
Testimonial: "I couldn't find any drivers for the vx715 on the viewsonic website when I looked previously but will look at the link you have posted. Thanks"
archaeology
  • 662 Answers
SOURCE: is there a special driver
If your monitor is a Gateway FHX2201Q, then your driver is at:
http://www.support.gateway.com/product/default.aspx?tab=1&modelId=3261
If your LCD monitor is an HD2200 series LCD monitor, then "generic PNP monitor" is it.
You can confirm by spending some time at the Gateway support site:
Posted on Feb 13, 2011
Where can I find the right driver to install a Viewsonic VE710b Flat Panel Monitor? I am running Windows 7, 64-bit **This connects to my VGA port, I already have 36" Samsung conntected via HDMI, and
Search Viewsonic.com. The Windows generic driver usually works. If you have a special video driver for your Samsung, it may be interfering. Multiple monitors have to be set up through your display driver. The viewsonic should be available through the device manager.
Oct 10, 2014 | ViewSonic Computers & Internet
Stuck on 640 resolution
INSTALL CORRECT GRAPHICS DRIVER
Jun 07, 2013 | MAG M24LM 24" LED Monitor
Acer S232HL driver did not install I want it instead of the Generic PNP driver. Help please
Good for you Barb, in the future be aware the for display adapters you can simply remove them and you would be prompted to re-install a driver for it at reboot.
It will by default use a generic monitor driver so you just cancel out the install and then run the setup off the CD.
regards,
Mike
Oct 07, 2012 | Acer S232hlAbid 23 LED LCD Monitor 2 ms...
Windows detected my monitor as generic non pnp monitor and when i installed the inf file for lg monitor and updated and rebound to generic non pnp monitorit says device on vga and when i
I see you are having issues with you LG monitor.
What type of video card do you have on your computer? if I may ask.
And also did the LG Monitor come with a disc to install the Monitor.
The VGA means it is using VGA a a mode or type of cable connection for the Video, what cable are you using? are you using an HDMI connection for the Monitor/LCD or is it the Blue Cable on both ends if it is the Blue Cable then that is using VGA so it will say on VGA meaning it detects the video connection from that cable.
Are you asking because this shows every time you turn the LCD monitor ON , is that correct, if that is the reason it is normal.
The question I see is incomplete? and when you? what happens?windows detected my monitor as generic non pnp monitor and when i installed the inf file for lg monitor and updated and rebound to generic non pnp monitorit says device on vga and when i
Sep 01, 2011 | LG W1941S-PF Monitor
Is there a special driver for hd2201 or is the 'generic pnp monitor' driver the best/only one?
Feb 13, 2011 | Gateway HD2201 22" LCD Monitor
Benq G900W Monitor: Settings show as generic non-PnP monitor and
Mar 05, 2010 | BenQ G900W Monitor
Lcd driver for notebook, currently generic pnp monitor
All monitors on laptops are listed as generic monitors and use a standard microsoft driver. If you have a driver already installed for this monitor, highlight the monitor and right click on it and check the driver details. You will probably see a microsoft signed driver. The graphics or display adapter is the driver that makes things happen on the lcd screen. That driver, the one for the display adapter is the one to keep updated.
Below is the link to HP support for the drivers for your laptop.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3860153
Nov 26, 2009 | HP G60-230US Notebook
Computers & Internet Logo
88 people viewed this question
Alun Cox
