Question about Sewing Machines
My featherweight singer will not pick up thread in bobbin
    Champion:
  • 243 Answers
The singer 221 needs to be threaded with the flat side of the needle on the left side. The thread passes through the eye of the needle from right to left. If this does not solve your problem it may be out of time. You can remove the needle plate and watch the hook it should pass above the eye of the needle as you turn the handwheel towards you. First you need to make sure the needle is at the correct height before adjusting the timing on the lower shaft. You may want to take this in for service if your timing is off.
Posted on May 14, 2014
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
SOURCE: singer featherweight bobbin won't pick up needle thread
pull the bobbin case out by pulling tab or flapper forward (outward toward you) and take bobbin out of bobbin case, If bobbin has thread and that it is coming off bobbin free and is not hung up on bobbin case.
let me know if this helps you,
sec_duane@hotmail.com
Posted on Jun 29, 2009
SOURCE: Singer 301a Bobbin troubles
I just had this problem, too - if you have the manual, check out page 15. If you have removed the throat plate, you need to make sure that the position finger on the bobbin case base enters a notch on the underside of the throat plate. Fixed my problem right away.
Posted on Mar 12, 2010
Testimonial: "You are absolutely spot on! THANK YOU!"
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
Bought a featherlite 221 will not pick up bobbin thread have no manaul so am i threading it correctly or putting in needle wrong the machine is like new
I see Singer Featherweight Featherlite manuals, not a Featherlite as a stand-alone model name. For the Featherweight 221 manual try here: http://www.singerco.com/accessories/manuals.html and enter the model 221. Alternative site: http://www.singer-featherweight.com/ with the direct link to the manual here: http://www.singer-featherweight.com/sitetwopages/singfea.pdf .
I hope this helps.
Apr 30, 2011 | Singer Sewing Machines
NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Oct 24, 2009 | Singer Featherweight 140Q
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Singer sewing machine model 6012 c
hi
thank you
Dec 15, 2007 | Sewing Machines
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Singer featherweight bobbin won't pick up needle thread
Nov 10, 2007 | Singer Featherweight 140Q
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
