Question about Ingersoll Air Tools & Compressors
Power Module test 5
On our Ingersoll Rand Air Compressor there is an Alarm condition "Power Module Test 5" and mentioned on disply, that to reset tis alarm need to press RESET twice... But there is no RESET option on display. Before "Power Module Test 5" alarm we had got "VSD Failure Alarm 42" and also without RESET possibility.. Plese advice
2 Suggested Answers
  • 214 Answers
SOURCE: what is a vsp fault 10 alarm Ingersoll rand
A VSD 10 fault is bus oscillation. Quickly rising and falling voltage. Recommend having power company check incoming voltage for oscillation.Voltage can not vary more than 3 percent or alarm is issued.
Posted on May 28, 2011
On our Ingersoll Rand Air Compressor there is an Alarm condition Power Module Test 7 and mentioned on disply,
The power module in the drive isn't working correctly. The drive is dangerous to work on. You should call the factory for that.
May 17, 2016 | Ingersoll Rand Air Tools & Compressors
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
How to clear emergency alarm on Ingersoll rand air compressor r110ie a200
Pull out the e-stop button. Press the reset button on the controller.
Nov 30, 2015 | Ingersoll Rand Air Tools & Compressors
Reset change oil filter alarm after filter changed
I thought this is something that I.R. had to do but it's been a while.
Dec 18, 2013 | Ingersoll Rand Type 30 Electric Driven Two...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
What is a vsp fault 10 alarm Ingersoll rand
Mar 09, 2011 | Ingersoll Air Tools & Compressors
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
The compressor trip at main breaker
possible causes , do not use ext. cord on compressor unless it's HEAVY gauge, also if you have any thing else running on the same breaker, It might cause it to pull too much power.
Oct 06, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Air Tools & Compressors Logo
261 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
