Question about Universal NoiseHush N500 Bluetooth Blk and Charcoal
What is wrong with my NoiseHush N500?
Droid Razr M/4.1.2 + NoiseHush N500 My Bluetooth will not properly power on. This device is already paired to my phone, and has previously worked. Nothing has changed on the phone since the last time I used it. Now, it will not power on. However, when I plug it into my computer using its original usb power cord, the RED light comes on for about 3 seconds, then switches to solid BLUE indefinitely. The unit will not respond to pressing or holding any buttons, in either a plugged or unplugged state. My phone shows no sign of error, and believes it is connected to this device, with the Bluetooth service switched to ON. I have never connected any other Bluetooth devices to this phone, therefore it is not otherwise paired. Please help! Is there a secret RESET button somewhere? Is it just busted, or is it salvageable? Thanks!
  • Official Brand Answer
  • 3,100 Answers
Noisehush com Contact Noise Hush for assistance.
Posted on Jul 10, 2014
designyou
  • 13 Answers
SOURCE: Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Posted on Aug 02, 2007
  • 46 Answers
SOURCE: HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Posted on Jun 18, 2008
SOURCE: H700 unable to pair up 'service not supported'
Previously connected, but fails to send/response eventhough Bluetooth says it is. Putting the H700 on the charger, seems to reset the H700 to get it ready to pairing. After reseting Razor phone which H700 is on charger did the trick. Use the same technique that other used to hold the talk button while boom is closed and flip open holding talk button down. Run through the menus to bond.
Posted on Aug 25, 2008
  • 55 Answers
SOURCE: The pairing light won't stay
Open the boom of the reciever right after the light turns purple... if you do it fast enough it will stay lit.
Posted on Jun 29, 2009
SOURCE: Pairing H710 to a computer
Here's what I did - Go to Control Panel and search for Bluetooth settings. Choose the option to change Bluetooth settings and check the "Allow Bluetooth devices to find this computer." After successful pairing, uncheck this box. All is good.
Posted on Dec 20, 2009
Bluetooth in Mercedes CLK 500 Dropping
Do you need to have an app that it has to be connected to?
Jul 31, 2014 | Motorola Mobility Droid RAZR HD
Ince the last upgrade my car can find my Droid Razr HD without me shutting bluetooth off and on what is the problem
Was the Bluetooth working before? This is something that has worked for other users: Unpair and forget you phone/car pairing then, a Clear Cache Partition process then, re-pair all and try it out.
It's not a definitve fix but has worked for many people in the past.
To perform a Clear Cache Partition:
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/93162
Regards,
Gaby
Motorola Support
Jun 10, 2014 | Motorola Mobility Droid RAZR HD
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
Hi, i need to know how i can pair my bluetooth plantonics explorer 232 to my incrediable droid 2? when i scan to look for the bluetooth device my phone couldnt find/pair it...please help!
The Bluetooth device that your Droid 2 is scanning for must be in "Discoverable" mode:
1. (If not already off) Turn it off by pressing and holding the call control button. Hold it until the indicator glows red and emits a sound.
2. Now press and hold the call control button for five seconds until the light begins blinking red and blue, then release the call button.
3. You may now rescan for your Explorer 232 on your Droid 2 and Select it when it shows.
4. Enter "0000" as the passkey if you are prompted for one.
Sep 25, 2011 | Plantronics Explorer 232 Bluetooth Headset
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 | Cell Phones
Had lost my Plantronics 220 for a year. am trying to pair with my Droid. can't remember how to do this. don't have any paperwork with me right now. what do I need to do? simple instuctions for a...
To find the User's Guide, check here: http://www.plantronics.com/us/support/docs/index.jsp?prodId=prod5920006
On Page 4 and 5 it details how to Pair the Bluetooth device to your phone.
For an Android 2.2 phone:
  1. Turn Bluetooth Headset on according to instructions in the Users Manual
  2. On phone, Go to Applications --> Settings--> Wireless and Network --> Bluetooth Settings
  3. From this menu you can turn Bluetooth on and once its on you can choose to Scan Devices
  4. Select your headset from the list.
  5. You will be prompted to enter a PIN or Code. By default it is 0000 (4-zeros)
  6. You devices should now be paired.
Hope this helps.
May 12, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I lost my manual and don't know how to pair the headset to a new phone
Turn unit on - hold function button for 10 seconds
Led should flash red -blue-red-blue ...
on your moble device go into the search function
passcode 0000 (4 zeros)
if successful only the blue led should be on
Apr 07, 2011 | Naztech Noisehush N700 OverHead Bluetooth...
My blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Feb 09, 2009 | RIM BlackBerry Bold Smartphone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
Universal NoiseHush N500 Bluetooth Blk and Charcoal Logo
110 people viewed this question
Top Universal Radio Communications Experts
eradiostore
eradiostore
Are you an Universal Radio Communication Expert? Answer questions, earn points and help others
