Question about Denon DVD-2910 DVD Player
Denon 2910 CD player malfunctions
My CD's will not play on my Denon 2910 anymore. The DVD's have no problem and play fine (sounds and picture). However, when I enter a CD, the display indicates " loading" and then jumps to 00H00M00S. To the left of the time indiactor the word "progressive" is lit up in red.
I have no idea what th eproblem could be. Can anyone help?
  • 3 more comments
  • denon2910 Dec 13, 2007
    Very funny, just googled around and read this. I have the same problem. SACD, DVD, DVD Audio no problems. Audio CDs - even a brand new one - don't read in 8 of 10 tries (different CDs, but always same CDs cause a problem / don't cause a problem).
  • denon2910 Dec 14, 2007
    To add current status:
    Made Firmware Update (available on Tried again today:
    approx. 10 out of 40 CDs didn't work. Some even new / nearly unplayed ones. Some did work and then didn't or vice versa.
    -> maybe Firmware Update did some good, maybe it's a coincidence.
  • kjansch Dec 16, 2007
    I have a similar problem with my 2910, although it's SA cds and the occasional DVD it doesn't like. It simply refuses to read certain discs - I have even tried taking the disc back, swapping it for another copy of the same disc, and trying again - with no success. It seems to happen more frequently now than when the machine was new. It tries to read the disc a few times, then gives up, with the display stuck on 0h00m00s
  • bloomphoto Jan 24, 2008
    I have the same intermittent loading problem with CDs. Once I get the CD to load it plays fine. I do not have this problem with any other type of disk (SACD, DVD, DVD-Audio). I do believe this problem occurs less with CDs that I burn myself or copy from store bought CDs. A service center I spoke to said it is probably a laser adjustment issue but it costs $110.00 just to check it and there is a two week wait. I decided to try and live with it for now. I did a firmware update once but can't seem to verify what the latest firmware should be from the Denon site as they do not appear to post any firmware downloads for the 2910 anymore.
  • miloshima Mar 21, 2008
    Same as below - anyone having any luck with this?!?!
So, tiggers97, did it actually help/solve the problem? Where did you oil, and what kind of oil did you wind up using?
Posted on Feb 14, 2010
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Posted on Sep 11, 2008
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
Progressive scan problem
You need to clean your laser lens my friend. If that does not help, I'm afraid then that your laser assembly is going bad and on its last leg. The first clue to this is that you stated that the Cd's work and the DVDs do not work properly. The laser, when it gets weak, starts to mess up on the Dvds first but the Cd's will soon follow. Good Luck
Sep 05, 2007 | Denon DVD-2910 DVD Player
The video output doesn't appear to be working. I can play a dvd but all I get is the sound, no picture. when I select set up, again, no picture. how can I resolve this ?
double check to see if your cables are fully seated in their sockets, also if this still isn't helping try doing a manual check of the cables themselves your video cable might have gotten pinched and separated.
Dec 21, 2010 | Denon DVD-2910 DVD Player
Denon Dvd-2910 only displays black and white on the tv screen
this is not a serious problem. It just has to do with visual compatibility.
Change the DVD display to Pal or NTSC and set that of the TV to Auto or pal.
You might find the PAL/NTSC on the DVD remote, or on the button of the DVD. If it is not there, then Check display settings of the DVD.
As for the TV, Change to Auto or Pal from display settings.
Take care.
Jan 01, 2010 | Denon DVD-2910 DVD Player
Picture but no sound on DVD
press "setup" on the remote controller then "OK" go down to OPT1, press left or right arrow to get DVD. 'setup' or 'exit' to exit
Apr 07, 2009 | Denon AVR-1803 Receiver
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
Denon dvd 2910 locked up
You will have 2 choices here, replace it or have it repaied
Jul 06, 2017 | Denon DVD-2910 DVD Player
you could try this or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Denon DVD-2910 DVD Player Logo
1,582 people viewed this question
Top Denon Televison & Video Experts
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
