Question about Health & Beauty
Can stress cause hives - Health & Beauty
Swollen left side of face hives on face,neck and chest and itching had now for 5 days swelling gone down but hives and itching still here
You have an allergic reaction to something, maybe seafood you ate?
As long as the area of your lips, tongue, and neck is not swollen you are not in danger from this now.
See a pharmacist and ask for a strong anti-histamine. There are types which do not cause drowsiness, but heed any warnings about not driving or operating machinery.
If there is no prompt improvement see a doctor as there may be some other cause at work.
It would be useful to have a doctor investigate this with a test kit to find out the cause, as in future you should be careful of anything which causes swelling on the face and neck like that.
If you ever do get allergic swelling in that area again, especially the lips and mouth, go to emergency immediately.
Oct 15, 2016 | Cars & Trucks
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Ok so I have a 4 1/2 yr. old male pit. He's
Since when has a pitbull been a car or a truck?
Apr 10, 2013 | Cars & Trucks
My laptop will not boot, instead it goes to a blue screen that states it is not able to access the hive.
I think this is the exact error : Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION:
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
Oct 16, 2010 | Sony Computers & Internet
My dell pops up with a blue screen and says "STOP: c000021a (Fatal System Error)"
To resolve this issue:
  1. Create a parallel installation of Windows NT.For additional information how to do so, click the article number below to view the article in the Microsoft Knowledge Base: 259003 How and Why to Perform a Parallel Installation of Windows NT 4.0
  2. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  3. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  4. On the Registry menu, click Load Hive.
  5. Type the path to the System hive of the prior installation, typically%systemroot%\system32\config\system, and then click Open.
  6. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  7. Note the setting for the Current DWord value in the preceding registry key. This is typically0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  8. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Managerwhere XXX is the CurrentControlSet that you identified in the preceding step.
  9. Under the Session Manager key, note and then delete any PendingFileRenameOperationsentries.
  10. Click the TEST hive, and then click Unload Hive on the Registry menu.
  11. On the Registry menu, click Load Hive.
  12. Type the path to the Software hive of the prior installation, typically%systemroot%\system32\config\Software, and then click Open.
  13. When you are prompted for the name of the key, type TEST2.
  14. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
    HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnceEx
  15. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  16. Quit Registry Editor, and then restart your original installation.
Sep 30, 2010 | Dell Latitude D600 Notebook
The registry cannot load the hive file ?
backup the current hive file, and copy the hive file from repair folder to the config folder, that would solve the problem
Aug 27, 2009 | Microsoft Windows Server Standard 2003 for...
Hi, ihave a dell latitude d600 when i start up i get windows gui up, then i get a stop c000021a fatal error message stating that session manager sys process has terminated with a status of: oxc oooo26c...
  1. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  2. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  3. On the Registry menu, click Load Hive.
  4. Type the path to the System hive of the prior installation, typically %systemroot%\system32\config\system, and then click Open.
  5. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  6. Note the setting for the Current DWord value in the preceding registry key. This is typically 0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  7. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Manager where XXX is the CurrentControlSet that you identified in the preceding step.
  8. Under the Session Manager key, note and then delete any PendingFileRenameOperations entries.
  9. Click the TEST hive, and then click Unload Hive on the Registry menu.
  10. On the Registry menu, click Load Hive.
  11. Type the path to the Software hive of the prior installation, typically %systemroot%\system32\config\Software, and then click Open.
  12. When you are prompted for the name of the key, type TEST2.
  13. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
  14. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  15. Quit Registry Editor, and then restart your original installation
How and Why to Perform a Parallel Installation of Windows NT 4.0http://support.microsoft.com/kb/259003/EN-US/
Apr 13, 2009 | Microsoft Windows XP Home Edition
Bad Pool Caller message??
BAD_POOL_CALLER is a stop error message that is caused because of problems with the memory management.
There is a list of more than thirty such causes that can give you this error message. If the stop error is consistent every time the system is rebooted, the following method will be effective in solving the problem:
* The hardware and RAM should be checked initially.
* Boot the system once again using the OS setup CD, or use a boot setup that has a GUI like BartPE.
* With RunScanner it is possible to use a memory test tool.
* Select a single account
* If all the accounts open then the system registry hive might be the problem.
* Locate the hive damaged and rename it, do not delete it.
* Create another hive from the backup or from the restore point.
* Initially uses the latest one and keep checking the restore points that come later.
* Avoiding harvesting any replacement hives from the hard drive booted Windows.
* After which compare the hives for differences.
This is one of the ways of fixing BAD_POOL_CALLER errors. Another method is to reinstall the OS but occasionally shows a disk read error or an error on the same lines. Switching the computer off for a minute or more and then switching it on can solve it since the error is only a slight glitch in the system operation.
The BAD_POOL_CALLER is seen for the first time after installing a hardware or software it is recommended that the computer be restarted. If it doesn’t solve the problem, the installation of the hardware or software should be checked for corrections. If the problem persists the installed hardware and software should be disabled, and the BIOS memory options like caching or shadowing should be disabled too.
The safe mode can be used as well to remove or stop components.
To enable the safe mode just press F8 when the machine is being restarted and select it from the Advance Startup options and correct the problem. The installation of the graphics card is another reason the BAD_POOL_CALLER error shows up. A simple reinstallation of the driver can solve the problem.
Microsoft has also acknowledged that the BAD_POOL_CALLER Stop 0xC2 error pops up when trying to print a document that contains a corrupt font.
A hot fix is available at www.support.microsoft.com
Jan 10, 2009 | Computers & Internet
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
CAUSE
RESOLUTION
To resolve this issue, use one of the following methods.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
Type cd sytem32\config , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Oct 23, 2007 | Computers & Internet
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
