Question about Universal NoiseHush N500 Bluetooth Blk and Charcoal
What is wrong with my NoiseHush N500?
(Droid RazrM/4.1.2 + NoiseHush N500) The Bluetooth unit will not power up properly. My phone and this device are paired, and have been previously used together many times, but now the earpiece will no longer turn on. No significant changes have been made to my phone. When I connect it to my computer, via its original charging USB cord, the red light is ON briefly (~3 sec), then the blue light comes ON indefinitely. No blinking. There is no response to any pressing or holding of buttons in either a plugged or unplugged state. My phone shows no sign of trouble, and lists the device as paired and connects without error, at least from its end. Bluetooth service is powered on, but still no apparent functionality, besides a pretty blue light. Please help! Just how dead is it? It sounds flat busted to me, not just out of sync, but maybe there's a hidden RESET button I don't know about?
  • 13 Answers
SOURCE: Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Posted on Aug 02, 2007
SOURCE: H700 automatically disconnects though fully charged
I had the same problem. It does seem to be related to the battery. The solution--in my case--was to recharge the headset until the light turned green again and then flip it open and it hooked up again.
Posted on Apr 15, 2008
  • 46 Answers
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Posted on Jun 18, 2008
SOURCE: pairing s9 headphones w/krzr
OK I managed to get my head set to work. Make sure the unit is charged, press and hold both the 'ON' button (on neck piece) and the "PLAY/PAUSE' button on the right earpiece. Keep holding then the LED should flash Blue three times THEN flash alternate RED and BLUE. You should then be able to Pair the Device. Good luck
Posted on Jun 19, 2009
  • 3 Answers
SOURCE: Motorola H710 will not reset even when holding
If you can't reset your device- try this, which I just fiddled with and got mine to work (I had same problem). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps.
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
Posted on Jan 02, 2010
Testimonial: "You are so awesome! Had to open the boom and let go of the middle button before it reset to solid pink and phone picked it up and sinked!!! Thankyou!"
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
My bluetooth light shines blue on my cellphone,the phone says bluetooth is connected,but the headset does not appear to function,,,,it worked an hour ago just fine ,,,,i could not find any instructions for...
the bluetooth device battery is it charged and is it ok,if you live your phone very there is a distance limit then it goes on standby for a limited period then it automatically switchies off
Jan 20, 2014 | Naztech Noisehush N700 OverHead Bluetooth...
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
Hi, i need to know how i can pair my bluetooth plantonics explorer 232 to my incrediable droid 2? when i scan to look for the bluetooth device my phone couldnt find/pair it...please help!
The Bluetooth device that your Droid 2 is scanning for must be in "Discoverable" mode:
1. (If not already off) Turn it off by pressing and holding the call control button. Hold it until the indicator glows red and emits a sound.
2. Now press and hold the call control button for five seconds until the light begins blinking red and blue, then release the call button.
3. You may now rescan for your Explorer 232 on your Droid 2 and Select it when it shows.
4. Enter "0000" as the passkey if you are prompted for one.
Sep 25, 2011 | Plantronics Explorer 232 Bluetooth Headset
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 | Cell Phones
Had lost my Plantronics 220 for a year. am trying to pair with my Droid. can't remember how to do this. don't have any paperwork with me right now. what do I need to do? simple instuctions for a...
To find the User's Guide, check here:
On Page 4 and 5 it details how to Pair the Bluetooth device to your phone.
For an Android 2.2 phone:
  1. Turn Bluetooth Headset on according to instructions in the Users Manual
  2. On phone, Go to Applications --> Settings--> Wireless and Network --> Bluetooth Settings
  3. From this menu you can turn Bluetooth on and once its on you can choose to Scan Devices
  4. Select your headset from the list.
  5. You will be prompted to enter a PIN or Code. By default it is 0000 (4-zeros)
  6. You devices should now be paired.
Hope this helps.
May 12, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I lost my manual and don't know how to pair the headset to a new phone
Turn unit on - hold function button for 10 seconds
Led should flash red -blue-red-blue ...
on your moble device go into the search function
passcode 0000 (4 zeros)
if successful only the blue led should be on
Apr 07, 2011 | Naztech Noisehush N700 OverHead Bluetooth...
I have a droid x and a friend gave me an plantronics explorer 240 cause she had gotten another one. I thanked her not thinking to ask how it worked like what buttons was what and how to connect it to my...
First of all, go into Settings and then Wireless & Network settings on your Droid X, then push Turn on Bluetooth. The check mark in the box should be green once its on. Then click Bluetooth Settings. Meanwhile, turn on your headset by sliding the power switch towards the microphone. The light should flash blue and red. Now go back to your phone and push Scan for Devices, at which point you should see something like "XXXPlantronicsHeadsetXXX". Push that, and it should work. IF it asks you for a passcode, its 0000. Here's the Plantronics help site:
Feb 21, 2011 | Plantronics Explorer 240 Bluetooth Headset
Universal NoiseHush N500 Bluetooth Blk and Charcoal Logo
89 people viewed this question
Top Universal Radio Communications Experts
Sean Ware
Level 1 Expert
Mario van Limburg
Mario van Limburg
Are you an Universal Radio Communication Expert? Answer questions, earn points and help others
