Question about Frigidaire FGQ332ES Gas Dryer
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
Posted on May 16, 2014
Bottom of garbage disposal is dripping water! what could that mean?
First do some problem isolation to make sure the water is not coming from the supply lines dripping along the pipes, or from a leak at the sink/counter interface and just dripping down on the disposal and drain from up above because caulk is bad. Also check your sprayer hose to eliminate that. Best way is to dry it all completely with paper towels and a hair dryer and then watch what happens when you run hot and cold water. If it is a double sink, make sure it is not drain water coming from the other sink and migrating over to the disposal side. The reason for all this checking is that the drain connections are notorious for leaking when they are bumped like if you store pots and pans under the sink. Once you have pinpointed it to the disposal as you first believed, then you need to dismantle it and check the gaskets. G
Mar 09, 2015 | Electrical Supplies
I have installed the bathroom sink according to the directions (which need words along with the pictures) and the drain leaks. I used plumbers putty around the lip of the drain (instructed to by Menards)...
the sink drain through basin. you can use chaulking compound like for tubs. remove drain put a bunch of chaulking on drain outlet of sink, under drain on bowl of sink. let sit for approx. 10 minutes, then replace drain and tighten down. have a good day !!
Jul 11, 2011 | Moen Home
I suddenly have the smell of urine in my dryer. Nothing was washed with any urine residue. I always double rinse each load and often use a little bleach with my "white" laundry. A couple of...
The only thing that I can think of that could produce a urine/ammonia smell is a shorted capacitor that is leaking. But normally when that happens the dryer motor will not start.
Jun 17, 2011 | Dryers
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dryer stopped running after 10 minutes
Take off the back, there will be a oblong fuse, it has two little wires, replace it.
Jul 14, 2009 | Dryers
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Jan 30, 2009 | Dryers
Dryer stops after a few minutes of a full load.
You will have to replace the moisture sensor. The heat from the small fire may have damaged it. It's not that hard to do, but the part costs @$60.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire FGQ332ES Gas Dryer Logo
116 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
