Question about Magic Bullet Nutribullet Blender
Can't get top off - Magic Bullet Nutribullet Blender
Attachment stuck
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
May 10, 2014 | Cuisinart CSB-77 SmartStick Blender
JSM900DAAS Jenn Air Table Top Mixer, Flat Beater part
Try Reliable Parts.ca. Everyone else was out of stock for Jenn Air small appliances, but I was able to oder a part for my blender from them. Looks like they ship to USA
Apr 14, 2013 | Jenn-Air JBL800 Work Top Blender
How do i change the gear on the top of the Vitamix 5200
Remove beaker, remove big black rubber part from top of motor housing. At the back just below the gear you will see a small dob of white silicone, dig it out. That will reveal a gap to allow you to put an allen key in there. Inspect the top flange of the "gear" carefully, there is a nearly invisible arrow or marking in one place. Line that up with the gap at the back, that is where the allen screw is.Undo it and lift the gear off. Read the instructions that come with the new gear.
Oct 07, 2012 | Vitamix Blenders
Can't find replacement for glass top of Betty Crocker Blender BR - 301. I live in Halifax, Nova Scotia, Canada.
I bought a Betty Crocker blender at an auction and they put the wrong top with it. Where can I find the correct top for the Model # BC-1352 blendor.
Feb 09, 2010 | Betty Crocker Blenders
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Rubber drive wheel disintegrated. How do we replace?
The rubber wheel is known as the "coupler." To clarify: the coupler is a black, cylindrical rubber piece that juts out of the top of the motor base and you set the pitcher on top of it.
This part can be replaced through a Kitchenaid certified service center, where they can provide the part for you. It is a low-cost repair.
A listing of certified Kitchenaid locations may be found here:
http://caservice.kitchenaid.com/
Also, if you are interested in self repair, you may order the part and view do-it-yourself instructions here:
http://www.mendingshed.com/kacoupling.html
Apr 06, 2008 | KitchenAid KSB5 Professional Stainless...
Jenn air JBL 800 work top blender need a top lid
i called jenn air today (maytag) and they said no one is selling the part because it's discontinued. The stores that had them are now out.
Dec 09, 2007 | Jenn-Air JBL800 Work Top Blender
Help with a Dismantled Osterizer Classic Blender
With the unit upside-down and the bottom off the wires on the right side of the switch go like this:
yellow on top
black on middle
red on the bottom
No wire connects to the 4th connection point (top left side).
R.
Aug 17, 2007 | Oster 4134 / 4126 Classic Beehive Work Top...
Magic Bullet Nutribullet Blender Logo
50 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
