Question about Virtual Reality VR3 Car Amp
What should my setting be on car stereo...Keeps shutting off subs at half available volume.
It is wired correctly.. how should I set the gain? Radio is a pioneer deh-24ub..what hertz or ohms do i set this in the radio to control subs? Speakers are Lightning Audio 10" 750 watt @ 2.. Amp is a VRF3 400 watt 4 Channel
    Problem Solver:
  • 4 Answers
If your amp is shutting off when you turn up the volume it means that it's clipping. This is very bad for both your subs and amp. The reason this happens is because your amp doesn't supply enough wattage for your subs and the capacitors are being drained of power causing your subs to cut out. As far as ohms this is not a setting. It is resistance and is very very important to have your ohm load correct or it can cause damage to your amp n subs. For a better understanding of ohm loads visit http://www.the12volt.com/caraudio/woofer_configurations.asp and put the number of subs and the ohm value and it will give you the wiring diagrams for the different ohm loads. then u need to look at your amp manual to see what ohm loads it is stable at.
Posted on May 29, 2014
1000 watt 2-channel Pyle PDGA240 Gear X Series
Make sure that the gain setting on the amp is turned up high enough on the sub's amp.
Aug 26, 2013 | Car Audio & Video
My subs are skipping notes and only play low notes decently and only play when the volume is at full blast. The amp wiring is fine and the radio wiring seems alright. No idea why it is
First of all the bass needs to be tuned down on stereo you shouldn't need to turn volume fill blast then you set your amp so your subs sound good hope you have a cross over. Never tune the gain on your amp past 3/4 ether play with you air flow to that some times works I found that if you do this your bass gets louder less risk blow
Mar 02, 2013 | Car Audio & Video
My alpine keeps shutting down when the volume is turned up past 20. Plus I have no sound coming out of my subs. I tried switching rca cables. And I sent my amp off thinking it was my amp. Their is a little...
so it turns off suddenly and then the next second it turns back on and starts playing
from that and personal expericance i belive that the radio system (radio and amp) is not reciving enough power
is this radio inside a car
if so what car
what i would do is attach bigger thicker wires to the positive and negative of the amplifier
direct from battery
positive of battery>>>> positive of amp
metal grounding point on car>>>>>> negative of amp
(do not use negative of battery use the metal of the car)
May 12, 2010 | Car Audio & Video
Insignia NS-C5112 manuel. new sub getting too much sound through rca wires when turned up. sub amp shuts down. need to tune down audio in rca cables
does your new sub have a volume or gain control? If your getting the signal source from the line outs, then the volume level there is constant. You need to set it up so that it can be controlled by the main volume control.Or you might need a control pre-amplifier before your sub
Aug 18, 2009 | Car Audio & Video
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Aug 05, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Feedback/maxing out speakers.....
starting from amp,what is the rca connected directly to. headunit or adoption?
May 05, 2007 | MTX RT202 Car Audio Amplifier
Virtual Reality VR3 Car Amp Logo
115 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
