Question about Viper 7654V
How can you get a vehicle with a viper remote starter model: 7654v to stop randomly beeping when the vehicle is parked and not running?
3 Suggested Answers
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
SOURCE: viper remote starter-
Have this problem also. Took new vehicle (5009.2 miles) to dealer. They suggest that something in the control module tends to stick causing the battery to drain and that it is not an uncommon problem that they see. We had single digit temperatures here when the problem occured. It got up to 20 yesterday and everything works well again.
Posted on Jan 04, 2010
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Need operating manual for viper ce 0890
The asterisk button controls the remote starter feature. Press and release one time, wait. The parking lights should flash confirming that the unit received the command. If pressing the button one time doesn't work, try two times.
Jan 24, 2013 | Remote Start System
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
Bought viper 5501 yesterday.started car with remote but when i put key in ignition car stops running when key is removed car starts automaticly
Make sure you turn the key to the on/run position, then once you place your foot on the brakes to put the vehicle in gear the remote will beep and recognize the alarm.
Aug 20, 2011 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper 791xv carstarter/alarm the battery had to be replaced on the car and the alarm works but the remote sart won't start the car on key pad it shows it 's start but then it beeps and is gone...
The parking light flashes are a diagnostic report to alert you to the reason the remote starter is not working:
5 flashes; brake wire is active
6 flashes; hood pin is active
7 flashes; manual transmission mode is enabled and not initialized
8 flashes; neutral safety wire has no ground or the switch is OFF.
Count the flashes and you will be able to go directly to the problem. Enjoy.
Nov 26, 2010 | 791XV The 791XV is a 2-way Security and...
Cannot get to work with manual transmission please help with any ideas?
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Oct 12, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Feb 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Jan 15, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
we have a viper 600hf and it has recently started draining thebattery and it won't stay charged.
Feb 05, 2008 | Viper RCVGC022 Remote Control
Viper 7654V Logo
Top Viper Televison & Video Experts
Paul Bade
richie46
Gil Shultz
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
