Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Show me how yiu open motor to fix motor coupler on ghxp grass trimmer
My grass trimmer motor working but trimmer not spinning
  • 313 Answers
SOURCE: Black & Decker Grass Hog
possible broken plastic part of spindle assy.
Posted on Jun 19, 2008
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
  • 32 Answers
SOURCE: Motor spins, shaft does not...
sounds like the cable has broke inside the tube or it popped out of place. loosen the bolt on the motor casing holding the tube and separate the two pieces and pull the cable out. Should be a square at each end of cable.. if not post again
Posted on Jul 23, 2009
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Posted on Jul 26, 2009
rycgl
  • 1545 Answers
SOURCE: how to put together a black n decker grass
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Posted on Oct 12, 2010
The motor is working but the trimmer part stopped spinning. I checked the line but there is plenty, I removed and replaced the line spool but still not working.
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Jun 06, 2011 | Black & Decker 14" Grass Hog Xp...
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
The motor works but the head does not spin
Either lawn material is binding the head to the base or the reduction gear is broken, stripped, or melted. The motor's steel gear or belt drives the plastic gear which drive the spool. If claning doesn't help, then there is no user repair. The parts are generally not consumer available.
Apr 03, 2010 | Black & Decker 14" Grass Hog Xp...
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
Jul 23, 2009 | Black & Decker 14" Grass Hog Xp...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
24 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
