Garden Winds
https://gardenwinds.com
CUSTOM SWING CANOPIES BY STORE: Where did you buy your swing? Academy Sports · Ace ... Replacement Swing Canopies. Replacement Swing Cushions. Replacement Pop-
If you cannot contact Living Accents directly for a replacement set you might be able to take your existing ones to a local re-upholsterer. They may be able to re-cover or replace the cushions you have in any colour you like.
You have to remove the seat from the car, turn it over, and cut/remove all hog-rings holding the cover to the seat and pull the cover and cushion off. Set the new cushion in the cover, place it back on the seat frame, and hog-ring it back in place at the same points the original hog-rings were. Put the seat back in the car.
Yes, this can be accomplished by lowering the seat or raising the foot platform.The cushioned van seat can be removed from the seat frame and a wood platform covered in vinyl can be substituted. Sticky back Velcro strips are put on the vinyl cover to hold the cushion. The sticky back Velcro attaches to the vinyl covered wood platform and will mate up with the Velcro on the bottom of her existing cushion. The back cushion can be left in place. Pride makes this flat platform for all their models. You would need to specify the dimensions and style of the original seat to order the custom one. There is a manufacturer sticker under the seat with a series of numbers you can give to customer service at pride to help get the correct replacement platform. You can also raise the foot platform on the vertical adjustment post or attach a foot platform to the top of the footplate.
If this modification is not covered by insurance you can have a handyman remove the cushioned van seat and hack off the cushioned foam, springs and vinyl. He could then cover the wood with a durable material or sand and paint it before reinstallation.
Hope this helps.
