Question about Hitachi NV45AB2 Roofing Coil Nailer
Why is myhitachi nv45ab just rebuilt and leaks air from exhaust port
2 Suggested Answers
  • 1388 Answers
SOURCE: i have a nv45ab roofing
Hitachi nailers use an unusual design of actually moving the cylinder to fire instead of moving the headvalve. If the cylinder gets stuck in the open position (down), air will leak out of the head. To reset the cylinder, remove the nails and connect air supply. With air connected, lightly rap the head of the nailer against coiled air hose or soft rubber (too hard of a hit could damage the head). If after a couple of hits air still leaks, remove head and check headvalve for cracks. Replace as needed. If headvalve rubber looks ok, remove cylinder and clean/lube. If cylinder has fine scratches where orings make contact, sand smooth with 400 grit sandpaper. Lube with silicone paste, white grease or nailer oil.
Posted on Aug 02, 2011
Air suspension hummer h2
Your vehicle is equip with air bag system. You probably experiencing an air lost due to air bags leaks or your leveling valve is exhausting air at the exhaust port. Here is what you do. Spray soap with water on spray bottle and spray around the air suspension area. when you see bubbles coming out that's the leaks. fix it. Good luck.
Nov 16, 2013 | Cars & Trucks
My Hitachi NV45AB is leaking air from the trigger air valve. The gun still works if I just keep the trigger depressed and just smack the tip into the shingle.
Remove the 3mm roll pin holding the trigger in place and set aside the trigger plunger (white plastic plunger should have an oring on groove). Remove the fitting that holds the trigger plunger and replace vinyl ball #875645 or check for debris under ball. Good luck with your repair.
Apr 19, 2013 | Hitachi NV45AB2 Roofing Coil Nailer
I had my head ported out and now it leaks oil out where my exhaust mounts to the head is it safe to run my bike like that
It is not normal, The oil is coming from the engine lubrication system and it sounds as if you have not renewed the rocker cover gasket when the engine was rebuilt. Check the torque settings on the head bolts and that no oil is getting into the coolant.
May 22, 2012 | 2001 Yamaha YZ 426 F
I have a nv45ab roofing nailgun & it blows air out of exhaust on top any sug.
Jul 29, 2011 | Hitachi Tools & Hardware - Others
Senco sns40 stapler replaced all o rings still leaks air. Even seals in trigger assembly. Leaks out the exhaust port.
Air leaking thru exhaust on sns40 gun is indication of pinhole in rubber diaphragm of firing valve (part #BA0120). This gun is oil-less type and will develope leaks if oil is used. Most likely need to replace firing valve to restore to working order. Parts are at www.toolpartsdirest.com. Good luck
Mar 11, 2011 | Senco Air Tools & Compressors
Hi, i got a hitachi nv45ab and My nailer leaks air out the back
Hitachi nv45 series is the most popular line of nailers amoung professional roofers. There are three areas that develop leakes. Leak out head vent indicates cylinder stuck in lower position or headvalve worn. With air connected, gently rap head of gun against rubber mat to move cylinder to position. (Use caution not to damage head). If this action works, gun needs cleaning internally or lack of oil. If air still leaks out vent remove head and examine valve in head and replace as needed. Check that cylinder moves freely up/down (travel aprox 1/4"). If cylinder is hard to move pull cylinder and clean replacing orings as needed. If leaking around trigger, remove rollpin and trigger and check nylon ball for pits and replace as needed. If leaking around base of gun check for loose bolts and/or worn gaskets. Remove nail canaster to check feed piston gasket and screws. Good luck with your repair and post again if you have other question.
Aug 04, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi NV45AB coil nail gun is leaking air from top of gun
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
Jan 21, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Harley backfires threw xhaust loud pops
loud pops and bangs when throttle closed and you are slowing down is caused by air leaking in where the exhaust meets the engine, an air leak at the exhaust port. remove exhaust and fit new gaskets, make sure you remove all the old gasket first. don't over tighten the exhaust nuts, if you snap of a stud or a bolt there it's a real pig to fix.
Aug 15, 2009 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
A pb-200 blower won't rev high enough. I have 2 blowers and one won't rev as high as the other. rebuilt carb. changed fuel line. adjusted carb. changed plug and air filter. new gas mixture. checked exhaust...
Does it seem to have about the same compression as the other? Does it have equal spark? Any excess friction when pulling it through? When you had the muffler and carburetor off, did you notice any piston skirt damage visible through either port area. How about carbon build-up at the upper piston-side of the exhaust port--common on 2-strokes running heavy oil/fuel mixes. Worn/leaking crankshaft seals?
Jun 29, 2009 | Garden
Rebuilt nail gun and now it just blows air out the exhaust port
This probably is the problem,
The cylinder that the piston moves up and down inside is probably to low, and not making contact with the rubber piece in the head cap.
The cylinder has a spring that allows for movement up and down, take a pliers and gently pull up the cylinder if it does not move freely on its own. It will stop when it reaches the cylinder plate ( the part with 2 screw holes for easy removal). Be careful not to mar the cylinder though.
When reassembling the cylinder should make contact with the head cap. Hope that works!
Apr 23, 2009 | Hitachi NV45AB2S Coil Roofing Nailer
Hitachi NV45AB2 Roofing Coil Nailer  Logo
164 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
