Question about Xerox Office Equipment & Supplies
Skew adjustment xerox 260 - Xerox Office Equipment & Supplies
Hi, I have Xerox Wc M24.The Machine has Magenta Out Of spec.The Regicon Set up when Executed Shows NG.I have replaced all the 4 Drum Modules to see if it is creating a problem.I hv cleaned IBT Module...
There is a complete set up to do color registration.
it is a 4 step process. It's DC 685. E-mail me at rak458@aol.com.
I can send you more info that way.
  1. Belt Edge Learn - to align the Transfer Belt positioning system.
  2. Fine Skew Setup - automatically performs horizontal and vertical alignment, and reports any skew in the various images caused by ROS misalignment. This skew must be corrected through manual adjustment
  3. IN/OUT Setup - automatically performs magnification adjustment so that scan lines are the same length for all four colors. Also checks for skew.
  4. Center Setup - Aligns the midpoints of scan lines for all colors, for magnification balance
Feb 07, 2011 | Xerox WorkCentre M-24 Color Copier
XEROX 260 problem
Is the DCHP shut off on the machine? If it is on auto, it most likely changed the IP address.
Print out a configuration page, get the IP address and enter that into you web browser address box.
It sounds like the machine IP address has changed .
Mar 17, 2010 | Xerox Office Equipment & Supplies
Xc 830 problems
why not take the developer and drum units out of the skew copy one and put them in the other? At least that will tell you if dev/drum/toner is the problem.......
Skew copies on the other...look for torn corners of paper tight in the end of feed chutes etc, sometimes clearing a jam will leave a bit in there enough to slow down that side of the feed.If you can see any rollers make sure they are closed and parallel to each other and clean...
Jun 12, 2008 | Xerox 8830 Copier
22 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
