Question about Radio Communications
My cobra29nwst not transmit not recive but tx its working help me please
  • Mark Downey May 11, 2010
    is TX and RX both not working?
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    can you clarifiy please. Tx yes no Rx yes no do you get a signal from a nearby radio? does the pa work? AnyMHz.com Radio Shop
    www.anymhz.com
    Hwy 95 Temple, TX 76502
    254.718.4042
    Champion:
  • 219 Answers
Did you try another mic, this one is hard without looking could be a bad soilder or you're voltage regulator could have went out.
Posted on Nov 21, 2009
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
Dec 15, 2015 | Cobra 25 WX-NW-ST 40-Channels Base CB...
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Mar 12, 2013 | Radio Communications
I have a midland 77-151 it powers on but it doesnt transmit or recive the tx lights dont light up and the need on the metter doesnt move when the mic us keyed either.
I am sorry I am notfamiliar with this brandof radio.,so must askyoutoexplain further what the problem is.
That is if you cannot solve it with a new fuse, sometimes they do not need more help than that.
all the best
Kolbrun
Mar 06, 2012 | Midland Radio Communications
Does the rx/tx green light stay on all the time? Cobra 29LTD
Yes the light will stay on and change when you key the mic
May 07, 2010 | Cobra 29 LTD CB Radio
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Onkyo tx-sr804 ..problem with the remote
PRESS THE RECIVER BUTTON THIS SHOULD WORK THE AMP AGAIN.
HOPE THIS HELPS.
CABLE GUY.
Mar 26, 2008 | Onkyo TX-SR803 Receiver
No transmit or recive but works on pa mode
does this radio have freq? if so you could have turned on causing
a miss alignment with antena.. check all the switches move into different positions and keep keying up, good antena connection?
swr?
tony
Dec 03, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
55 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
