Question about Electric Kranzle Professional 1600 PSI Pressure Washer
What psi is required to move 1260gpm of water in a pipe diameter of 0.785 ins.i
2 Suggested Answers
alchiecez27
  • 641 Answers
SOURCE: what psi is required to move 1260gpm of water in a 1 inc diameter pipe
Try to check this guide.
Water flow pipe sizes
Posted on May 14, 2014
Can you put a 3/4 pressure relief valve on a water boiler that has a 1 inch valve on it with the same 50 psi
pressure is one of the variables - other is maximum flow, in case of pressure relief valve (safety valve) if valve was calculated at 50psi and flow of say 10gallon/sec, if you change the diameter, your flow will drop significantly, in case of 1" drop to 3/4" drop will be by nearly 45%! and that is significant drop...
i would suggest do not use reducer but 1" relief valve as required...
if you wan to establish bit more calculations on the subject, go to this site and have play with variations, sele3ct correct calculator and enjoy :
http://www.tlv.com/global/TI/calculator/
reverse engineering will be here:
https://www.physicsforums.com/threads/calculate-water-pressure-coming-out-of-a-pipe.274737/
hope this will help you a bit - do not forget to vote...
Feb 23, 2015 | Water Water Heaters
Hi i got a main pipe bringing in water
I wouldn't put psi any higher and it should run two small homes
Oct 03, 2014 | Water Sport
Water does not stop from drain pipe
Hello, welcome to FixYa.
I understand you have a Whirlpool washer, "water does not stop from drain pipe", correct ? You didn't specify if this is a top load or a front load, so I'll reply with a general rule of what may be happening based on your description...regardless of what type of washer it is.
To address this, and as long as water is indeed entering the unit here`s what I find is most common when dealing with the symptom you`ve described ( as long as water isn't filling over the top on top-load machines...that indicates a different issue ) I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far.
If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, ( refer to your manual, but it is typically recommended to be about "48 to "60 in height but not more than 90" or so )
**The standpipe drain requires a minimum diameter standpipe of 2" (5 cm). The minimum carry-away capacity can be no less than 17 gal. (64 L) per minute. A 2" (5 cm) diameter to 1" (2.5 cm) diameter standpipe adapter kit is available. " The top of the standpipe must be at least 39" (99 cm) high and no higher than 96" (244 cm) from the bottom of the washer.**
Also if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon. Check your drain hose.
Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there. Thank's for coming to FixYa and good luck.
Regards,
Macmarkus :)
Oct 12, 2011 | Whirlpool Washing Machines
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
We just moved and now my washing machine (which was working properly) won't fill. The water just drains out. Could it be off cycle? Please let me know any suggestions you might have.
You specified this is a new or recent install, and as long as water is indeed entering the unit here`s what I find is most common when dealing with the symptom you`ve described ( as long as water isn't filling over the top...that indicates a different issue )
Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there.
Regards,
Macmarkus :)
Jun 02, 2011 | Admiral AW22 Top Load Washer
Where is low side of a/c system to cahrge with 134
The low pressure side of the r134a system is always located on the thicker pipes vs. the thinner pipes leading away from the compressor.
So, just followi the larger diameter piping from the compressor until you come to a quick connect fitting that attaches to the hose quick connector that is attached to a can of r134a.
The pressure reading should be 25 psi to 45 psi on the low side when the compressor is turning and the a/c is on.
If it's higher than this, the compressor may not be turning, and the normal non turning psi is 75psi to 100 psi or so on a hot day.
Aug 26, 2010 | 1999 Jeep Grand Cherokee
Where is the ac lowside port located on a 2005 gmc savanna van
The low side port of the 2005 GMC savanna Van is located on the low pressure side of the compressor.
This is found by locating the compressor driven by a belt that has a clutch that engages and disengages as the a/c cycles.
The low pressure piping is always in the larger diameter piping, and the high pressure side is always contained in the smaller diameter piping.
Therefore, follow the thick pipes from the compressor up to the accumulator, which looks like a large can of soup. On the accumulator receiver/drier is a port that connects to the tube that is connected to the can of r134a freon refrigerant.
Simply quick connect the tube to the low side port, which is located on the 'thick' tubing or on the accumulator and then fill until the low side pressure is 25 psi to 45 psi while the compressor is running.
When the car is off and the compressor is not running, the pressure should be 75 psi to 100 psi on a hot day.
Hopefully the system doesn't have a leak slow or fast in it.
Aug 17, 2010 | 2005 GMC Savana
Volume of water in pipe work
3.14 x Diameter x Diameter / 4 x length= Volume in Cubic inches Diameter and Length are in inches.
Multiply the above volume by 0.004 to get gallons.
Jun 11, 2009 | Plumbing
Electric Kranzle Professional 1600 PSI Pressure Washer Logo
Top Electric Garden Experts
Steve Oakes
dannydoesita
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
