Question about Kitchen Appliances - Others
How can I set the timer for a seven sector Dewbee by Irritrol?
I need a copy of the manual for a Dewbee sprinkler controller by Irritrol.
    New Friend:
  • 11 Answers
The same manual for Irritrol's early MC Series may be used. I no longer have any Dewbee or MC Manuals but I do have written instructions available that should help. Let me know if still needed.
Posted on Jan 15, 2015
2 Suggested Answers
  • 496 Answers
SOURCE: i need a user manual for an irrigation controller.
See if this is your controller. Link to User's Manual:
http://www.irritrol.com/controller_manuals/pdfs/manual_totalcontrol24.pdf
Hope this helps... Good luck!
Posted on Sep 28, 2009
My TC-15EX-R suddenly stopped turning on all my valves even though it worked perfectly the day before.
You need a meter to check the voltage output to the valves. It should be 24 Volts AC. If you have no valves being opened then it is either a power supply issue or a bad common wire.
Jul 20, 2015 | Irritrol TC-15EX-R 15 Station Outdoor...
Display pulsates...doesn't allow me to run Manually - when I push Manual read out displays OFF...doesn't sequence to next station
Unplug it and take out the battery for a minute to see if it resets. If it does not, you need to replace it.
Apr 18, 2015 | Irritrol RD600-INT-R Rain Dial 6 Station...
Toro controller rd900 ext
The battery is a back up, There should be connection to a transformer to operate the system.
Jul 14, 2014 | Irritrol RD900-EXT-R Rain Dial 9 Station...
Orbitz sprinkler timer
What are you controlling?
Copy following link for Intermatic timers.... install 48 consecutive 156T1950 trippers on the dial, and timer will be ON for 12 hours. Timer arrives with 12 trippers, and you order 3 more packs for 48 trippers.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Add a comment and describe what you are using timer for.
More sprinkler timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Link above includes 'all' sprinkler timers on market today
Jun 03, 2013 | Electrical Supplies
Irritrol rd 900
IT'S NOT THE TIMER: The hydraulics in the valve are stuck. Best solution is to purchases same valve and replace all the internal parts with the ones from the new valve.
May 15, 2013 | Irritrol RD900-EXT-R Rain Dial 9 Station...
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Sep 10, 2012 | Hardware & Accessories
Manual timer setting goes back to zero when you hit start
Irritrol manual has troubleshoot section, reset protocol, web address, and toll free number. 1-800-634-8873
http://www.irritrol.com/controller_manuals/pdfs/manual_raindial07.pdf
Typical solutions include resetting timer and replace fresh 9V battery.
Check that programs do not have conflicts.
Check 120Volt power source for correct voltage, and to ensure correct polarity and grounding, and possible ground fault: test black wire to white and to ground, should read 110-125V, test white to ground should read 0 volts. There should be no flicker in the power source caused by bad connection.
Line should be clean with no interference from fluorescent lights or motor on same circuit.
Temperature range 32-140 F
Max output 24Volts ac 1 amp max, .5 amp max per station
I recommend Intermatic T8845PV mechanical timer instead of digital timers, because there are fewer problems with battery and surge and programming and load restrictions and line interference, and Intermatic mechanical timer parts are replaceable so timer can last decades.
Jul 31, 2012 | Hardware & Accessories
Sprinkler station drives another station by mistake
change the control valve for line 2. the coil is not pulling the plunger all the way in.
Apr 30, 2009 | Nelson SoloRain Irritrol Valve Adapter
Kitchen Appliances - Others Logo
598 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
