Question about Coffee Makers & Espresso Machines
Krups xp52 - after lights stop blinking I press the cup button and immediately the machine shuts down and the steam escapes from the safety valve. What is the problem?
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 3 Answers
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
Posted on Dec 05, 2009
SOURCE: steam escapes from the join
Some steam may escape even when the pot is put together correctly. However, make sure that the metal strainer disk is correctly nested in the thick rubber washer on the underside of the top piece, and that the washer is seated tightly and evenly.
Posted on Dec 12, 2009
  • 39 Answers
SOURCE: Krups XP2070 Stops putting water through after a
Most likely a faulty flow meter unit which is not providing the right information to the control unit. Replacing is not too difficult and the replacement meter is < $20.
Posted on Dec 29, 2009
  • 39 Answers
SOURCE: The espresso side of the
The clue here is that the problem involves the hot wate and the single or double espressos. These three functions require accurate water measurements and they are programmable. It appears that the flow meter is not sending the correct information to the control unit. This could happen if you have blockages or if the flow meter is not working anymore. Most likely you need a new flow meter which only costs about $20 and should not be too difficult to replace. It is located between the water tank and the pump.
Posted on Dec 31, 2009
We have a Krups Nespresso machine that cuts out within seconds, even with no pod in place. It works by holding the button down constantly but could this damage the machine?
To programme the quantity you would normally hold the button down continuously for as long as it takes to fill your cup to the required level. Next brew you make should require a single touch & release it should then flow through as much water as the previous cup and then stop automatically. If it's not holding the programme I can't see any harm in holding the button down until the cup is full.
Oct 10, 2016 | Krups Coffee Makers & Espresso Machines
How do I reset the machine to the 50ml/cup factory setting?
I have a similar problem that the 1 cup (50ml) setting now produces about 150ml and the two cup setting just keeps going until the machine is empty.
The manual says press and hold the 1 cup button until it starts flashing together with the power light and the coffee starts flowing, then press the 1 cup button again when you want it to stop and the machine will memorise the new setting. I tried this on mine and it didn't work - I'm guessing something has worn out but dunno what...
Jul 17, 2010 | Krups XP 4050 Espresso Machine
I lost the manual and i can't reset the clock on the machine. how do i do this?
reference: Setting and Adjusting the Clock • The machine must be “off“. • Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“. • Adjust the hours in steps by pressing the h/min button (n). • Press the prog button : the minutes will blink“ XX 88“. • Adjust the minutes in steps by pressing the h/min button. • Confirm the setting by pressing the prog button.
Mar 17, 2010 | Krups FMF5 Stainless Steel 10 Cup Coffee...
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
The blue light is blinking, the water tank is full, but the water isn't heating up at all. should we return it? Or is there something that we missed? We followed the instructions and are getting no where.
blinking light means the water circuit requires priming.
1 - press power button.
2 - place a cup under steamer and turn on full.
3 - turn steam off when blue light stops blinking (probably a few ounces of water in your cup).
4 - you're ready to rock!
Aug 18, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Magic Comfort Plus still producing steam in "off" position.
This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
The espresso side of the machine stops pumping water after 5 seconds or so. At the same time the espresso on/off button and main display start blinking. Pushing the hott water/steam button will reset this...
Sep 06, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
