Question about Flotec Plumbing
Need a flotec 2hp pump bossy or housing leaking in the joint
5 Suggested Answers
  • 10 Answers
SOURCE: pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Posted on Jan 11, 2009
john224
  • 1378 Answers
SOURCE: Flotec pump problem
Thank you for posting your question here on Fixya.com.
No, only a thermal overload. If the unit was hot and has had a chance to cool off it should start. If you have voltage to the motor and it will not even hum or buzz, you need a new motor. The short must have blown the winding open.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 28, 2010
aquaman987
  • 927 Answers
SOURCE: I have a Flotec 1/2 hp jet pump. Is it posible to
Use Google and put in Flotec parts.
I did that and several parts dealers came up.
Pick one and put in your model number.
I'm sure you can find a housing, the pump that I looked at had one available.
Gary
Posted on Jan 29, 2011
packrat1948
  • 528 Answers
SOURCE: My Flotec Model FPSC3200H-01 1/2hp
Well I know it a dirty job but someone has to did. Unhook the pump from the plumbing and take the pump out so you can see what fell into the sump pit and is lodged in the impellers.
If you have it out already turn the impiller backwords and see if that frees it up.
Posted on Feb 05, 2011
My flotec pt4012 shallow well 1/2hp is leaking water from the pump. please help. It's a yr old
Usually it is the pump shaft seal located where the motor shaft turns the pump. It consists of two ceramic faces that are held together with a spring:
images?q=tbn:and9gcsqhemjvhz47gerqjd8xbjrm6rs_krzskup94w7_irt2dnk22eh
Feb 01, 2015 | Flotec Plumbing
Flotec Model FP4012-D8 stopped pumping water. I took pump apart except for small impeller housing edge break I can see no reason for no suction?????
Hi jandh40...
You have an air leak somewhere in your piping, housing of the pump or maybe the mechanical seal and that is causing your pump not to pump.
Try to disconnect the piping and hook a water hose up to the pump and turn the pressure on, it should show you where the air leak is by spraying water out of the leak area.
Please take time to rate me
Aug 15, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a Flotec 1/2 hp jet pump. Is it posible to get just the pump housing. Mine froze cracked the housing?
Gary
Jan 29, 2011 | Flotec 1/2hp Cyclone Pump
I replaced old pump w/ Flotec 1/2HP FP4012 and replaced old pressure tank w new 35gal tank. Pump primed but cycles on-off every minute constantly even w/ no water turned on. Goes to 50PSI, loses pressure...
The water and therefore the pressure has to be going somewhere. If you are sure that there are no leaks in the house or outside, then the water is going back into the well. There is a check valve either in the suction line of the pump between the top of the well and the pump or down in the well.
If this check valve fails, it allows water to go the wrong way and back to the well. The result is that you lose pressure.
Secondly, you have to be sure that there are no air leaks between the top of the well and the inlet to the check valve. Leaks in that piping will make repriming difficult.
Write back with more and I'll try to help more.
Gary
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
My flotec well pump will squirt water and then stop . I keep feeding it water slowly but it won;t prime. What should I be doing?
Check for an air leak in your siphon line. It can be very small and totally prevent the pump from priming.
Jun 08, 2010 | Flotec Corrosion Resistant Shallow Well...
The plastic part that houses the impeller cracked on my flotec fp4012-001. Is there a replacement part?
you would have to contact flotec----there should be a part for it,, depending on the age of it, they change the covers all the time to get people to have to replace the whole unit
Jun 21, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump works but is not pumping water
Jan 11, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
32 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
