How do i remove agitator from maytag mav7600aww washing machine?
Oceti
  • 51 Answers
SOURCE: Older Maytag Washing Machine - Top Loading "Heavy Duty" model
There is a screw near the base of the agitator. If it is missing replace it with a stainless steel screw. If this is a machine that is older than 25 years, you will have to replace the rubber ring on the agitator shaft.
Posted on Dec 07, 2007
aborcass
  • 2651 Answers
SOURCE: How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Posted on Mar 12, 2008
  • 6 Answers
SOURCE: How to remove agitator from Maytag A410 top loading washing machine
Remove the screw holding it down with a 1/4 inch nut driver.Look at the agitator from above and you will see a hole ,there is 1 only.Once you find tha follow from the hole up until you find the set screw and remove it
Posted on Jun 24, 2008
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
Panel removal
top load or front load
Oct 08, 2014 | Maytag Washing Machines
How do i remove agitator from mav7600aww?
you can remove it by>>>>>>>>>>>>>>>>>>>>>>>..................
May 14, 2014 | Washing Machines
Mav7600aww maytag spinning but not agitating
RDU Appliance Repair 919 827 1482 Serving Raleigh Cary Durham NC
mav7600aww has a brake that goes bad. some will just spin slowly during agitate cycle and not really agitate
Sep 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7600AWW--will not rinse and spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 16, 2010 | Maytag Washing Machines
How do you remove the agitator from a Maytag washing machine Model A407 series 02?
Loosen the 1/4 inch hex nut on the side of the agitator about 6 inches up from the bottom.
Then pull up on the agitator.
Nov 11, 2009 | Maytag Washing Machines
Have a Maytag washing machine MAV7600AWW.
sometime not always it wont spin also the water temp is more on the cold side
Aug 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
