Question about Acer Aspire 6920 Notebook PC
Aspire 6920 after power up, goes to black screen
  • Acer Master
  • 32,281 Answers
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 24, 2009
Hi, Cant boot up my Acer 6920, regular start up or in safe mode. Just takes me to a black screen.
Hi. Try to perfrom power drain to your netbook. Take out the battery then unplugged the power adapter. Press and hold the power button for 30 secs. Put everything back in then turn on the computer. If same problem will happen then you need to contact ACER and have your computer srviced for LCD problem.
Oct 11, 2010 | Acer Aspire 6920 Notebook PC
I have an Acer 6920 laptop, for some reason the screen has lost all colour (now only black and white). it is colour during the boot sequence but just after loading the desktop icons it goes black and...
i have an aspire 4520 laptop and it's been a long time I never used it because the keyboard is broken. One day try to open it and the screen was white or sometimes blurs. what should i do?
May 07, 2010 | Acer Aspire 6920-6621 Notebook
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
Acer Aspire 6920 will not turn on. With or with out hard drive inplace. Pushing power button makes the keyboard lights come on but not the computer screen or hard drive. Pulled hard drive and connected to...
I had same problem with my aspire 6920.Tried power reset didn't work. Tried replacing memory chips,No go . Pulled rest of my hair out,still nothing . Then I checked memory chips again and noticed that the inner chip was not seating correctly due to a design flaw in the retainers. Gave both retainers a gental tweak,reset chips. And most importantly Disconnected CMOS Battery and held power button in for 1 min. Plugged everything back in and Bingo... Fired right up >>>And to the comment about plugging in the HD ....Mine fired up with out it ..
Jun 18, 2009 | Acer Aspire 6920 Notebook PC
Black screen shortly after logging into Windows
it sounds like you may be having an overheating issue with the CPU, or you may have a bad stick of memory,for the overheating you can try to alleviate it by elevating the back of the laptop, and/or use a laptop pad with fans, the memory, you can run memory diagnostics, goto control panel, administrative tools, and memory diagnostics, scan the RAM and check the results/log for errors, and replace the stick or sticks of RAM if more than one shows errors. Those are the two most likely culprits given your description. I hope this solves your problem, if so please give a fixya rating, every one of them helps.Thanks for the question
May 27, 2009 | Acer Aspire 6920 Notebook PC
Help
hook the aspire to an external monitor and see if you get any output if you do then it is the back light or inverter most likely.on the pc-bad display~ power supply ~ motherboard~video card or processor pretty much in that order and you can test by substitution ~hope this helps
Aug 30, 2008 | Computers & Internet
Acer Aspire 6920 Notebook PC Logo
228 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
