Question about Frigidaire ATF6000ES Front Load Washer
There is a little bit ofwater leaking from underneath the washer.
There is a little bit of water leaking from underneath the washer. I checked the hoses that connect from the water taps to the washer and that's not the problem. The washer has been unused for about a year, but stored in the house and drained.
  • Mark Nichols May 11, 2010
    Could be many of things, you will need to access the inside of machine and let it run and see where it is leaking..
    Sniper:
  • 120 Answers
The bolts on the drum case are probably loose.
Remove the rear cover to access to bolts
Posted on Jul 10, 2009
IW709A Has water leaking underneath machine wondering what it's caused from. Hose underneath has a little bit a water showing. Maybe a split in hose is this possible?
I had a similar problem awhile back with my maytag washer,it had a steady little stream and I thought was the discharge hose but after checking the hose out it ended up being the seal in bottom of the pump, I set the front on some 2x4's and used my little mirror and flash light and could actually see drips I hope this is helpful to you thanks td
Jun 11, 2017 | Washing Machines
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
It leaks a bit of water every wash
Check all of your hoses and see if it is wet. Don't neglect to check the water supply hoses for your hot and cold water. 9 out of 10 the leak is directly under the washer so if you can tip it on it's side you will a good view of the underneath carriage. Good Luck
Jan 07, 2011 | Kenmore Oasis HE 27062 Top Load Washer
Water leak
first you should open the unit and find out if the leak is coming from a hose or the pump or maybe a crack in the tub
Jul 25, 2010 | Miele Novotronic W1918A Front Load Washer
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Water runnning out from bottom of washing machine
Barbarahaps,
I had a similiar problem with a Brand X washer. the problem may be your water pump. if so, it is an easy fix for someone who is mechanically inclined. you first must see where the water is leaking from. when i did this, i securly placed my washer on cinder blocks so that i could see underneath it, and let it fill with a little bit of water, then i could clearly see the water leaking out of the water pump. the key concern here is safety, make sure that the machine fills with only a little bit of water, and then cut the power off to the machine to ensure it doesn't start going through its cycle while up on the blocks, creating a potential hazard. If it is the waterpump, find a washer repair store, tell them the year and model machine you have, and get a water pump on order. the water pump is a pretty straight foward repair--you disconnect power from the machine, turn off and disconnect the water supply, disconnect the drain pipe, and tip over the washer to expose its under side. you disconnect the hoses going to the water pump, remove the attaching bolts, and install the new pump. then you hook everything back up and you should be good to go. hope this helps.
Nov 28, 2008 | Speed Queen AWS52NW Top Load Washer
Gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Water leaking from bottom of washer
you need to fill it up a little then switch it off. tilt it backwards and if it hasnt got a base you should be able to see where the water is coming out of. check the bottom hose and around the element location.
Jun 23, 2007 | LG WM-2277HW Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
111 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
