Question about Sony Alpha DSLR-A200 Digital Camera
A200 stabilizer faulty - Sony Alpha DSLR-A200 Digital Camera
  • 30 Answers
If your stabilizer is bad you will notice the pictures will not be as framed in the viewfinder. You can compensate by slightly framing off center a bit. Most of the time the picture is lower and off to one side slightly. This is a pricy fix if repaired. You can still take nice pictures but just compensate or recrop the picture with an editor. This is not an uncommon problem. Considering you have a a200 you can pickup a nice used on for probably less than the repair cost.
Posted on Jan 04, 2015
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sony Expert
  • 322 Answers
Could you tell us more about your problem? The stabilizer might not be faulty and there might be a way of you making it useable, but there's no way of telling without additional info. The only thing to do is refer you to the user manual and hope it offers some help:
Sony DSLR A200 manual
Posted on Dec 13, 2014
Visor view
Some of ALPHA DLSR are prone to have such problems on antishake mechanicsm. I stucks and fails. You start to see a black line or twisted view instead to correct image seen on optical visor. You either need somebody to service it or you need to remove ccd board and fix the shaking mechanism by trial and error. Fixing means really fixing it to surface that it wont move anymore. Since this will allow framing corect you will loose anti shake function. though situation. Check the link. you are not alone.
a200 sensor shake stabilization malfunction dropped camera
Apr 02, 2014 | Sony Alpha DSLR-A200 Digital Camera
What causes noise and vibration in the lens whe. turned on axa100
It's almost certain that some part of the lens or the supporting framework are faulty. You can try troubleshooting the device with the user manual, but you will probably need to have it repaired. Try checking out the user manual to be sure:
Feb 07, 2014 | Sony Alpha DSLR-A200 Digital Camera
1993 honda goldwing fuel, temp gauge not working and running lights too
These are generally on the same fuse and run through a voltage stabilizer to stop fluctuation due to charging, could be the stabilizer that's gone faulty.
Oct 17, 2013 | 1993 Honda GL 1500 Aspencade Gold Wing
Toshiba satellite A200 is not booting it has ablackscreen
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 16, 2012 | Computers & Internet
Problem disassembling Stabilizer from Samsung Refrigerator RT-24BDWI
There is no stabilizer on a RT 24 BDWI, I would say the PCB is faulty, before replacing, check the defrost element, this is the usual cause of PCB fail on this model, not too costly but well worth replacing if replacing PCB, replace the element then test the unit, if still no go, replace the PCB. ...Russ
Aug 06, 2012 | KitchenAid Refrigerators
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
My toshiba a200 does not work on charged battery ,but when plugged in it sometimes works and sometimes cuts and dies and shows flashing blue light and refuses to boot at this stag.e,can you help...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 13, 2010 | Toshiba Satellite A200-0ET00X Notebook
Does a Toshiba Equium A200 have a built in microphone?
Here are two different spec sheets for the A200-1V0 & A200-196. Neither one lists a "built-in mic" but both support external mics via 3/8 jack. Also there's always the possibility of using a USB mic.
A200-1V0
A200-196
Hope this helps, if so please comment, vote, etc.
Thank you.
Jun 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba A200 and the screen is completely
Sounds like the screen is faulty I would check the screen connection to make sure its not lose but I would say the screen is almost gone.
You may need to replace it.
Feb 25, 2010 | Toshiba Satellite A200-19501F Notebook
Toshiba sattelite a200 won't turn on
Try removing the battery. It might be faulty and shorting the adapter.
Oct 31, 2008 | Toshiba Satellite A60 Notebook
Sony Alpha DSLR-A200 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
