Question about Electric Cycling
Wiring diagram for e v warrior bicycle
Can you wire e v warrior electric bicycle to 1 12 volt battery
jeltey
  • 44 Answers
SOURCE: need a wiring diagram for a barbie 12 volt two battery jeep !!!!!
When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
Posted on Dec 02, 2008
  • 53 Answers
SOURCE: wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Posted on Nov 05, 2009
SOURCE: wiring diagram for electric motor
The more I look at this motor the more I think that it is a stepping motor and not an AC motor... I could be wrong, but checking the windings and seeing the small Tach Motor on the rear leads me to believe that this is not a ac motor, but a stepping motor and is triggered from the programmer for rpm
Posted on Apr 16, 2010
  • 3 Answers
SOURCE: electrical wiring diagram is required for Peg
Here is a link to the wiring diagram http://peg-peregoparts.com/diagram.php?num=IGOD0511#W
Posted on Dec 02, 2010
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Posted on Dec 18, 2010
'92 mercury grand marquis wipers don't work, headlights blink on and off, power windows don't work, a/c don't work, battery keeps dying.
Well Angela the only way to find out why these thing's are not working or not working correctly would be to do electrical testing ! Find wiring diagrams of the affected circuits an get a DVOM - digital volt ohm meter . Do you know how to do basic automotive electrical testing ? How to use an read a wiring diagram ? Voltage drop testing ? Your battery dying , depending on when it dies , over night or while driving would need different testing procedures .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
How to read an electrical diagram Lesson 1
The Trainer 29 Understanding How Electrical CIrcuits Work and How to Test...
http://www.bbbind.com/free_tsb.html you can find wiring diagrams here . Watch the videos , buy a volt meter , do some testing ! Good luck
Mar 20, 2017 | Mercury Cars & Trucks
2004 Hyundai Tiburon interior lights work and button to unlock trunk works but no power windows, headlights or anything else the ignition is dead won't state on turn on for that matter. Please help
Do you know how to test automotive electrical circuits with a DVOM - digital volt ohm meter ? How to use a wiring diagram ? How to locate componets , electrical connectors that are inline of wiring harness , how to test a fusible link ? Do you know what a fusible link is . Start by viewing videos on youtube for basic automotive electrical testing . Electrical Troubleshooting Basics EricTheCarGuy < how to read a wiring diagram an if you don't know how to use a volt meter ,watch on that too . Electric Testing Techniques You Need to Know Look at a wiring diagram at http://www.bbbind.com/free_tsb.html Looking at the ignition switch diagram i see a fusible link supply's it with B+ voltage. . Check voltage at the battery - 12.6 volts is what it should be . pull the ignition switch , the electrical part .Check for B+ voltage on the orange wire ,terminal 2 Check the starting circuit ! Is there a anti-theft system light on ?
Mar 05, 2017 | Hyundai Cars & Trucks
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
How do you charge the EV warrior?
You need to obtain an "EV Warrior SuperCharger". I just found a few on Ebay for about $80
It is a 5A-24v battery charger with a standard 3 Prong Connector
Jul 29, 2014 | UPG 12V 18AH Electric Bicycle Co EV...
Wiring Diagram For 12Volt Monster Trax Convertible Car 12-Volt Battery-Powered Ride-On
type: redman 12v red convertible schematics or wiring diagrams search google images I found the pics!
Sep 20, 2013 | 12Volt Monster Trax Convertible Car...
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
I want to add 2 more 12v 20ah batteries to my 48w electric scooter and im not sure how to wire it and charge it.Please help
join them in parallel if there all 12 volt you could just charge the 1 battery with 12 volts and that would charge them all but all the other batterys have to be in series you cant do it if u have 2 24 volt batterys they all have to be 12 v
Dec 18, 2010 | Electric Bicycle Motor, Bike,electric...
Battery connections
Check the voltage rating of the motor (for example 12 volts). If the voltage rating of the battery is half the voltage rating of the motor, then connect one bike wire to the + post of the first battery, connect the - post of that battery to the + post of the second battery and connect the second bike wire to the - post of the second battery. This is a series connection. Two 6 volt batteries connected in series will provide 12 volts. If the voltage of the motor and the battery is the same there would be another connector so I do not think that is the case for your setup.
Jul 28, 2009 | Electric Bicycle Motor, Bike,electric...
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Cycling Logo
24 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
