Question about Microwave Ovens
GE microwave jvm1740dm1ww will not shut off
Door closed, microwave runs. Have to unplug or leave door open.
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Posted on Nov 07, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Won't shut off
Chances are you have a shorted door switch, but all owners of a GE WES model might want to look at this blog post.
If it's been less than 30 days since you bought it, I'd hurry and take it back to the dealer for a refund, not an exchange.
Otherwise, GE Customer Service is here.
Posted on Oct 11, 2008
  • 15 Answers
SOURCE: fan runs when door is closed
This is an interlock issue or a faulty temperature sensor. Both will require the outer casing to be removed for inspection. Basic tests can be done with a continuity tester or cheap digital multimeter with resistance checking facilty (Radioshack)
The sensors for these types of fans are normally attached to the roof of the cooking cavity, little silver components with two or more wires.
Check these out with a meter if any are open circuit then they need to be replaced.
Posted on Dec 10, 2008
  • 234 Answers
SOURCE: door latch hook broke on bottom, when closing
You can find the parts at a GE appl.dealer.
Posted on Mar 19, 2009
wiringlunati
  • 576 Answers
SOURCE: Microwave GE Spacemaker JVM1650SH05 - The light
The bulb may have blown. It is often under an access panel on the side or back that is held on with a screw or two.
Posted on Jan 26, 2010
JVM1740DM1WW
There are three microswitches. All are interchangeable.
This will give you the idea.
V3 Microswitch SPDT 16A Micro Switch eBay
Match the type of actuator and order a couple.
Aug 14, 2017 | GE Microwave Ovens
How to replace door switch on advantium
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
Jan 28, 2013 | GE Advantium 120 Convection/Microwave Oven
GE Microwave will only run about 3 seconds, then shuts off. I've unplugged, let it sit and tried again. Same thing. Help!
I have a workaround for you, that works for other brands. I am not sure if it will work in your case though. Pls try it:
- It seems that the door closing sensor is not working well, so it might think that the door opened.
- Once you have this problem, open the door and then close it again.
Normally it should work...
Nov 21, 2012 | GE Microwave Ovens
GE Microwave JVM-1190WY Is always on with the door closed. Need to open door to shut down,. Is the power relay stuck on?? Do I need a new power relay?/ Joe Ziomek 305-664-1221
Please check your e-mail. I answered this directly.
Jun 20, 2011 | GE JVM1190SS Microwave Oven
My ge microwave just runs. It will not stop unless I unplug it.
First you should determine whether it's cooking when it should not be, in this case anytime it is plugged in and the door is closed or open.
Do that by putting a cup of water in a microwave-safe container into the unplugged microwave, shutting the door, then plugging it for about a minute.
Then unplug the oven and check to see if the water is warmer.
If so, you have a shorted secondary relay on your microwave''s control circuit board, and we regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
Do that test again by putting the water in, leaving the door open, and plugging the oven in for about 30 seconds or so. If you get any arcing or buzzing or flashing, unplug it.
If it is not cooking, then you need to test further.
If it just seems to be "running" with the door shut, but it is not cooking (as shown in the above tests) then note whether the oven lamp, internal cooling fan and turntable are running when the door is shut, but when you open the door, the turntable and colling fan go off.
This should mean you have a shorted main relay on the board. We can fix that, too.
Differing symptoms would indicate a bad door switch or door switch mount.
Our info file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 30, 2010 | GE HVM1750SMSS Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't shut off
The door switches are what tells the microwave that the door is opened or closed. If they play up they could be causing your microwave to act strangely.
Mar 25, 2009 | GE Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Won't shut off
Oct 09, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
