Question about Granberg Garden
Where can i buy granberg bushman mowers - Granberg Garden
IhaveaSHARP-N-EZY chainsaw sharpener[G712]Granberg for myozito 1800w chainsaw.The only instructions is a 1 page pamphletwith 8 instructiion The problem is that they are not very detailed instructions.
There are much simpler devices on the market, the Husqvarna roller gauge is really good and easy to use, if any device is hard to use it generally doesn't get used.
Nov 15, 2017 | Garden
Sharpen chain with an electric sharpener
Having cut a lot of wood when I was younger I know from experience just how important a sharp chain is.You need a guide so all the teeth cut at the same angle.If I were doing it now I would use an outfit like this.You will find that when your out cutting that it won't take much to dull a chain and that cuts in to the sprocket that turns the chain.A sharpe chain will throw big chips whill a dull chain will through out small chips because it's scratching the wood instead of cutting it off.We just used files without guides.I never did get the hang of that But my partner did.This is what I would use today.By the way never use a chain saw alone ,that way you have some one to help you if something goes wrong. I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.I am not endorsing this site just the type of tool.
right-tool_2143_15026
right-tool_2147_24719010trans_1x1.gifright-tool_2147_24738108
The Precision Granberg Chain Saw Grinder combines the features of the Grind-N-Joint with the accuracy of the File-N-Joint. Easily clamps onto the saw bar for fast, precise, and stable chain saw sharpening.
This grinder requires threaded stones. SEE BELOW.
GI-G1012Ctrans_1x1.gifRegular: $70.00trans_1x1.gifSpecial: $59.94trans_1x1.gif
Calculate Shipping Rates Zip Code: Country:
trans_1x1.gif Granberg G417-3 5/32" Grinding Stones (Threaded # 31399)trans_1x1.gif3-Pack
trans_1x1.gif trans_1x1.gif Granberg G418-3 3/16" Grinding Stones (Threaded # 31401)trans_1x1.gif3-Pack
trans_1x1.gif trans_1x1.gif Granberg G419-3 7/32" Grinding Stones (Threaded # 31400)trans_1x1.gif3-Pack
GI-G419-3trans_1x1.gif$9.27
May 27, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
I have a craftsman 21 bushman hedge trimmers I need a piston ring can you help
Go to : Searspartsdirect.com and enter the complete model number (minus the decimal point). This will take you to a series of parts drawings and associated parts lists. Common parts like common nuts, bolts, and washers are ridiculously priced, but other parts seem closer to reason. Hope this helps!
May 25, 2010 | Garden
Looking for instructions for McCulloch File-N-Joint chainsaw sharpener, part no 61034
Please start here. I have dialed this number many times looking for an OM (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response.
Granberg International
http://www.granberg.com/contact.html
This is probably the real manufacturer. I would request instructions for their unit. It is in the "File Guides and Holders" category.
They also call it a "File-N-Joint" pn G106B. HTH
Lou
Feb 20, 2010 | McCulloch Garden
Broke the anchor base. Need replacement #124
Yours is a file guide and holder. If they do not supply repair parts they should be willing to supply the address of someone that does. HTH Good Luck Jacob
Lou
Feb 09, 2010 | Granberg Bar Mount Chain Saw Sharpener,...
My anchor base broke - part number 124. Were can I get parts?
Granberg.com
Yours is a file guide and holder. If they do not supply repair parts they should be willing to supply the address of someone that does. HTH Good Luck Earl
Lou
Setting for sharpening
they sell gauge for different chain types
Aug 03, 2009 | Granberg Bar Mount Chain Saw Sharpener,...
Need instructions for Granberg File and Joint chain saw sharpener model 106B. Seems simple but I've been unsucceful at getting it set up properly. Where can I get an instuction manuel or can you help me?
You can contact the manufacturer here:
They should be willing to provide the instruction you need.
Please let me know if they helped. If you get an internet link I'd like to have that as well.
GL and TIA
Lou
Apr 15, 2009 | Granberg Bar Mount Chain Saw Sharpener,...
Garden Logo
41 people viewed this question
Top Granberg Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Granberg Garden Expert? Answer questions, earn points and help others
