Panasonic PLL Multiplex Circuit. Model Number SE-5808 ...no sound or static
2 Suggested Answers
SOURCE: I have a Panasonic
Most likely needs a new needle. Try needlelady.com or needledoctor.com Modern record players usually track at 2 to 4 grams of pressure. Thats about as much as a penny weighs maybe. Putting more pressure on it, will only cause it to destroy your records or sound bad. Weight adjustment is usually a very fine spring or counterweight that adjusts on the tonearm. Linear units use optical sensors to keep the tonearm aligned, but use traditional counterweights to control force. You need a gram scale made for phonos to properly adjust it. Radioshack USED to sell them 30 years ago, but most times you can just use a guess if the needle only slightly deflects when placed onm the record your usually good. If it's simply jumping and sliding across the record then the needle is shot. Even diamonds don't last forever,. as they are synthetically produced.
Posted on Jun 19, 2011
Testimonial: "Thank you!"
Turn table wont turn on panasonic pll multiplex circuit
Makes no sense. Multiplex circuits are part of FM stereo transmission - turntable has nada to do with it!!!!!!!!
Sep 30, 2016 | Panasonic Audio Players & Recorders
Why is my FM not working on my Panasonic multiplex circuit receiver
Peter, check your antenna, and try switching your am/fm button a bunch 15 to 20 quickly, of times to see if it is a bad or dirty switch.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Feb 15, 2016 | Panasonic Re-7670 Fm-am Multiplex Stereo
What is the EHT number for sansui TV model no. PJ29 multiplex?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to may popular brand devices are given.
Apr 10, 2015 | Sansui Televison & Video
How do I turn on the audio in the Toshiba Se-0047 remote control
I suspect the problem is with the DVD and requires the audio settings to match the type of audio connection you have used, Digital sound or Analogue Sound. see setup for audio in this similar DVD model user manual. I did not know what your DVD model number was but it should be similar in setup to the one below in the link.
http://service.us.panasonic.com/OPERMANPDF/DMPBD60-MUL.PDF
Apr 09, 2014 | Toshiba Se-r0047 Dvd Remote Control
How do I turn on the audio in the se-0047 remote control
148 gtl off freq
Check the PLL
check the wires connected at PLL
It is operated with air channels?
Unlocked frequencies?
Change PLL Integrated Circuit
Nov 09, 2013 | Cobra Radio Communications
I have a Panasonic pll multiplex circuit and when I put a record on it skips a lot. I have another record player at my other house and it has an adjustable weight on it, and I am thinking that that's...
Jun 19, 2011 | Audio Players & Recorders
Power locks don't work with remote or control from
The door lock/unlock input from the driver's key switch goes to the Door Multiplex control unit (main switch), the Door multiplex control unit then sends a signal on the BUS (CAN) circuit to the passenger's multiplex control unit; the passenger's multiplex control unit then controls all the door locks. The passenger's door lock key switch inputs to the passenger's multiplex control unit, if the locks work from the passenger's side key switch but not the driver's side key switch, the most likely cause is the driver's multiplex control unit (main switch) not sending the signal to the passenger's side multiplex control unit. This could also be the drivers side door lock actuator. Hope this helps!
Jan 07, 2010 | 2003 Honda Pilot
Static record
To find this information you will have to either go to the Panasonic customer support website and enter your palmcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the palmcorder. Explain to them the problem you are having with the fuzzy picture quality from the recordings of your palmcorder. I Hope this information helps you with your palmcorder problem.
Oct 18, 2007 | Quasar VM-D51 Camcorder
60 people viewed this question
 Grubhead
Grubhead
