Question about Acer PH110 Multimedia Projector
Acer ph110 fault
On startup, shuts off within 30 seconds
Ricoh MPC3003SP SC672-11. what are the possible solutions to this error. i have already replaced the controller board
No. Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
672 D
Controller start up error
? After the machine is powered on, the communication between the
controller and the operation panel is not established, or
communication with controller is interrupted after a normal startup.
? After startup reset of the operation panel, the attention code (FDH)
or the attention acknowledge code (FEH) is not sent from the
controller within 30 seconds.
? After the controller issues a command to check the communication
line with the controller at 30-second intervals, the controller fails to
respond twice.
1. Controller stalled
2. Controller board installed incorrectly
3. Controller board defective
4. Operation panel connector loose or defective
5. The controller is not completely shut down when the main switch is
turned off.
? Check the setting of SP5-875-001. If the setting is set to "1 (OFF)",
change it to "0 (ON)"
Feb 13, 2017 | Ricoh Office Equipment & Supplies
I have a acer projector ph110, it telling me to replace the globe. Change the globe but can't get into the menu screen to reset globe hours. Try pressing the menu botton but it stll have the warning...
Hi, I had the same problem all you have to do is connect something to the projector like a laptop or dvd player so it has a signal. Once the picture comes up of what you are projecting from the laptop or dvd player you can enter the menu and reset the lamp hours. Hope this works for you if not please let me know.
Mar 30, 2011 | Acer PH110 Multimedia Projector
Changed lamp and now turns on and only stays on for about 5 minutes and red lamp light stays on in an acer ph110 projector
Hi, what you need to do is reset the lamp hours to get the red light to go if it is a new lamp. To do that plug in a source such as a laptop or dvd player. When the display from the laptop or picture comes up go into the menu and reset the lamp hours I had the same problem. Hope this works if not let me know.
Nov 10, 2010 | Acer PH110 Multimedia Projector
Projector shuts down after a couple of minutes with lamp and temp lights flashin, is this a fan poblem and can i replace the fan?
This probably the fan is not cooling down the temperature of the high intensity bulb. Due to overheating the bulb will shutdown. Get a correct specification fan to replace the aging fan.
May 30, 2010 | Acer PH110 Multimedia Projector
Calling for a older friend> ac power outage happened within 30 secs of each other. Now computer comes on and begins startup showing screen but shuts down and starts up all over again and again
Unplug everything, wait a few seconds and retry startup. But it almost sounds like a virus or malware was uploaded into the computer. Also try startup in "Safe-Mode". Hold down key marked "F8" after pressing the power on button.
May 20, 2010 | Computers & Internet
Not recognizing any source
Hi, i hope this works for you, all you need to do is press the source button this makes the projector search for active inputs.
Nov 06, 2008 | Acer PH110 Multimedia Projector
DRIVER FOR WINDOWS VISTA
www.acerpanam.com/synapse/forms/acerdrivers.cfm
Jun 26, 2008 | Acer PH110 Multimedia Projector
Dark Colours pixelate on screen
hey i have the same prob with mine (same model) but it only happens when i send the picture through the rca video in. if i use my pc and use the 15 pin plug, it works fine. i cant explain why it happens, but i jus know it happens.
Aug 11, 2006 | Acer PH110 Multimedia Projector
Acer PH110 Multimedia Projector Logo
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
