Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Freezer compartment temperature at 30-32 degrees F
I have had my defrost timer replaced and the freezer is still not freezing. The repairman says today it COULD be a freon issue. My luck I won't have the 5 year warranty. Refrigerator was purchased October 2007.
  • Mitzi Jun 23, 2009
    There was occasional frost on the back of the fridge. And yes, it does run like normal. You can hear the normal sounds. Repairman did call back and yes, it does seem to be freon. We're waiting on a repair estimate now.
HE'S correct i've seen many refrigerators with the same problem as yours.
Posted on Jan 05, 2010
  • 351 Answers
He is probably right , no frost and the machine is running like normal?
Posted on Jun 23, 2009
Where is the defrost timer on a Magic Chef Model RB23GA-3A top freezer Refridgerator?
It is located in the mechanical space of the unit. Please review the picture.
Feb 23, 2015 | Magic Chef Refrigerators
What could the problem be; my refrigerator not cold but the freezer is freezing?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail with illustrations how to dx and fix: Refrigerator Defrost Parts
Jul 31, 2014 | Emerson Cr500 Refrigerators & Freezers
The freezer part keeps freezing up but the refrigator side is too warm
Several things to look at. first make sure you defrost the freezer fully, (you can use a
hair dryer to defrost the coils behind the back panel of the freezer).
Then I would
replace the "defrost termination thermostat" It is clipped onto a tube and has two wires
going to it, this is an inexpensive part that often causes this failure. Model and serial
number is inside the big door usually on the left side.
Also make sure the fan operates in the freezer compartment, as well as setting the
knob in the freezer to the center and not "COLDER"-- this knob blocks off air flow to the lower compartment if set to "COLDER" and can cause freeze up.
Rotate defrost timer until you hear a click and listen for water dripping in
freezer or a hissing as the element heats up. Defrost timer is accessed by a hole under the temperature control panel that has no screw in it in the lower compartment. Rotate the timer manually with a flat screwdriver until it clicks. They sometimes stick.
Hope this solves the problem.
Jul 03, 2011 | GE Refrigerators
Re: Tempurature Problems
The thermostat is likely failing intermittently, or the defrost timer could be failing.
Both parts can be tested (and should have been) by the repairman.
The defrost timer turns on and off to let the coils defrost - but if it stays off - can cause the rise in temperature. The thermostat, however, reports the temperature to the timer, so either (or both) could be to blame.
Have them tested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Bottom freezer has high temperature and is defrosting. temperature alert light is on. Tried fast freeze button and turning up the temp gages but nothing seems to be working.
as for high tempreture do u mean it is above the 0 degree normal that its supposed to be set to your freezer goes into a defrost cycel once every 6-8 hours.if your tempreture is rising on the other hand there are a couple things for you to check make sure the fan inside the freezer compartment is running.the following things you will need a meter for to measure the resistance while the power is off check the t-stat,heater to make sure there is continuity if you have continuity in both of these then you would need to check the defrost timer If you are unable to do these tests i strongly suggest you call a technician
Apr 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 | Freezers
In the back of the freezer there is a ''condenser'' unit that leaks & ice forms along the back of the freezer and bottom. I have opened a drain hole & attached a hose but the water freezes before...
Good day,
First, if ice maker equipped, the fill tube going into the ice maker may be leaking. Shut the water off to the machine, and disconnect the line for now. It can be addressed later.
Although a pain, I would recommend the machine be un plugged for 24 hours and melt and dry out the freezer compartment. If you have a floor fan to blow into the freezer compartment, even better.
Second, There is a limit thermostat clipped to the top of the evaporator. It's a round 1" device.
If I have a problem machine with this problem, I bump the temperature of that tstat 5 degrees.
For example, if it's a 50 degree tstat, I replace it with a 55 degree.
If 55 degree I replace it with a 60 degree. If 60 already, I replace it with a new limit of the same value, since there is nothing above 60 degrees that makes sense. This is to guarantee the old one isn't opening prematurely and not producing enough heat.
As an option, and you might want to wait on this, there are timers that have a longer defrost cycle to aid drainage.
Timers have a defrost cycle that runs between 20 minutes to as high as 35 minutes. Longer is better.
In this case an appliance parts house is your friend.
With the complete model number, ask the counter what cycle your timer has. If your in the 20 minute range, I suggest you go to 30 or 35 minutes. A sharp counter man should be able to find a substitute. GE timers run commonly in the upper range.
I know it sounds like we're trying to kill a flea with a sledge hammer, But in an attempt to make the machine more energy efficient, over the years, they have cut back on defrost time, defrost heater temperature, and heater wattage.
P.S. The timer is mounted in the housing on the top in the fresh food compartment.
Dec 04, 2009 | Refrigerators
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Kenmore Fridge, freezer compartment is cold according to thermometer, but ice wont freeze & frozen foods thawing out, weird. Fridge part is about 65 degrees. What could it be?
Should be around 10 degrees.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Refrigerators
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
302 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
