Question about Springfield Measuring Tools & Sensors
Why wont record outside temp - Springfield Measuring Tools & Sensors
My C4 Corvette wont allow the heater or the A/C to come on. I replaced the control panel and everything on it works. Temp, blower etc: All fuses check out as OK. What's next in line to check?
Edward,
C4 Corvettes have an Outside Air Temperature sensor which may be faulty. It senses air temp in front of the car and tells the climate control unit (which controls the heat/ac) what the temp outside is. Yours is in front of the grill. It's a $20 part. It looks like the attached link. I'm not sure if this is your issue, but it was on my son's car. I just thought it might give you a direction to check.
Fred-
C4 Corvette 1986 1989 Outside Air Temperature Sensor
Dec 05, 2016 | Cars & Trucks
1988 ford escort wont start if is hot outside
A common problem with Fords in hot weather is a weak ignition module. Some are mounted on the side of the dist. The coil can do the same thing.
Jun 24, 2012 | 1988 Ford Thunderbird
My outside temperture display runs about 10 degrees hotter than the actual outside temperture. can this be adjusted?
im not sure if this can be abjusted or not but i can tell you why its saying its hotter that in realy is.. its because its telling you the temp under the hood. its recording the heat from the engen.....so this adds a few degrees to the actual outside air temp.... i hope this helps you
Sep 09, 2011 | 2002 Ford Explorer Sport Trac
I cant get the outside temp to work on my pro 3300 it wont display the temp.
Go into option mode, scroll through the options until you see TEMP N, press the dark buton to change it to TEMP Y and the unit will display the temperature.
Mar 03, 2011 | Whistler Vehicle Parts & Accessories
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
Air conditioner wont work if outside temp is over 70 97 chev pick-up it works great in temps remain cool outside any help would be helpfull.
Sounds like you are low on freon and as it gets hotter outside your AC system can't keep up. Check into getting the system charged and that should take care of it for you. Thanks for rating my response and for using FixYa!
Jun 28, 2009 | 2002 Chevrolet Impala
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Outside temp stuck on -40
when its at -40 usually its because the ambient temp sensor is not sending the proper signal to the controller.. it may just be disconnected.. the sensor it behind the grille.. it has a 2 wire connector to it ... itf its connected it may havea broken wire from body damage in an accident... its rare that the sensor fails..
Jan 30, 2009 | 2001 Chrysler Town & Country
Measuring Tools & Sensors Logo
Top Springfield Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
