Question about Exercise & Fitness
Hyundai elevator error code f54,what I have to do?
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: What is the error 75 for elevator? HYUNDAI ELEVATOR Type STVF 7 How to solve this problem? Lift suddenly can stop any floor as not level. Thanks
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on May 19, 2016
I have a HYUNDAI luxen- passengers elevator traped between two floors, No sign at the hall call point, and giving an ERROR CODE F74 :(
Put in an emergency call to Hyundai - they have operators who can talk you through this situation. Or... call whichever local company services your elevators.
Aug 13, 2014 | Exercise & Fitness
Kenmore Elite oasis washer code F54
F54 is a Motor Control Overcurrent.
1) check to see if there is anything between basket and agitator this can cause this error.
2)move the basket .. should move freely
if all is clear then most likely you will need a new motor
Jun 12, 2013 | Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
F54 code
It is detecting a high current load when trying to turn the tub. Lift the top of the washer by using a putty knife and insert it between the top and front panels about 3 inches from each side, push in the clip and lift the top. You will find a tech sheet glued to the inside of the front panel in a plastic bag. Go to page 3 and look up your error code, it will refer you to page 4, test #3. I explains how to test the motor assembly.
Oct 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Sep 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Dec 01, 2008 | Kenmore Oasis 27042 Top Load Washer
Kenmore Oasis F54 code
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel. Good luck
Dec 09, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Exercise & Fitness Logo
124 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
