I get disc error message on my TASCAM cd recorder
TASCAM CC222SL MKII CD/CASSETTE RECORDER GIVES "DISC ERROR" MESSAGE WHENEVER A CD IS INSERTED. POSSIBLE CAUSES/FIXES?
  • 76 Answers
SOURCE: Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
Posted on May 15, 2007
  • 169 Answers
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
Posted on Sep 07, 2007
  • 3422 Answers
SOURCE: Tascam CD A500 'No Disc' error message
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on May 01, 2008
  • 99 Answers
SOURCE: I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
Posted on Jun 15, 2009
SOURCE: Re-insert the cassette error message
SMACK THE CAMERA ON EITHER SIDE REAL HARD
? what does it mean plz?
can you explain for me plz?!!
Posted on Apr 23, 2010
Why Tascam CD-RW750 Error recording?
I don't have experience with your model. I have the 1000 model and I would try a different brand of CD discs. You don't say what error message that you are getting.
Jul 18, 2014 | Tascam CD-RW750 CD Recorder
Tascam CD recorder lost power
There a switch on the side of the recorder that says "hold". Try switching it.
Apr 04, 2013 | Tascam CC222 MKII CD Recorder and Cassette
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
Can i translate tascam cc-222slmkii owners manual to spanish?
If it is strictly for personal use, I do not see why not, there are numerous translation programs that people could use and it would be no different in the end.
If you wanted to take it to market, that is a different matter- contact Tascam first and see if you can work something out with them so they can distribute it..
Jan 30, 2012 | Tascam CC 222SL MKII CASSETTE CD RW...
Need belts for tascam 102 mk2 cassette player
This is easy to take care of just contact Marrs Communications and select the
Supreme" CASSETTE KIT $19.95
http://marrscommunications.com/tascam-cassette-kits
Oct 11, 2011 | Tascam 102 MKII Single Dual Cassette Deck
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Technical manual for TASCAM 112MKII
If you go here: http://www.tascam.com/products/112mkii;9,20,2,19.html
and click on the resource tab, you will find downloads for Tech info and an owners manual.
Apr 15, 2009 | Tascam RC-134 Wired Remote Control for 112...
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
37 people viewed this question
 Grubhead
Grubhead
