Question about Motorola Cell Phones
Why does the phone say restricted when calling the number? I can't get into voicemail either.
    New Friend:
  • 115 Answers
Could have been blocked from other phone.Go
into settings you will find all in there.
LUCK
Posted on Dec 13, 2014
  • 40 Answers
SOURCE: voicemail number (Tracfone)
try dialing: 1 and then send. The number does not have to be stored in your phone book as it is usually part of the pre-loaded software
Posted on Dec 07, 2007
SOURCE: not recieveing incoming calls go straight to voicemail
call cricket cause sometims that would happen to my phone but it was just because they messed up my bill and got it confused with someone elses
Posted on Apr 28, 2008
t1randa
  • 27 Answers
SOURCE: deleted voicemail access number
also can reset factory settings on some but will lose numbers,messeges,etc.
Posted on May 27, 2009
Blackberry_U
  • 223 Answers
SOURCE: voicemail doesn't work
I would check with your cellular provider to make sure that they kept your voicemail when you purchased the new phone.
Posted on Jun 03, 2009
SOURCE: wehn checking voicemail from land line, how to obtain ph #
lost voice mail phone number landline
Posted on Dec 31, 2009
Type your problem for a solution...HOW DO I FIND OUT WHO CALLING MY PHONE RESTRICTED? I DONT HAVE HER NUMBER.....HER NAME IS VICTORIA BROWN 25, TEXARKANA,AR 71854
You can check your phone records at the end of the month, sometimes providers will "unmask" restricted numbers when they put them on there. You'll have to note the date and time of a call though. Another way to do it is to call up your cellphone provider and ask them how to go about blocking restricted calling. Usually it's a setting on the phone itself, but every phone is different. You can then change your voicemail to say something about you're now blocking restricted numbers, so if they want to get in touch either leave their number in a voicemail so that you can call them, or unblock their number.
If you're getting harassed by someone with a restricted number, you'll obviously want to call the police. They can get all this information almost instantly.
If you're trying to find the number for Victoria Brown, and it's not listed, you might not have any luck. However, I've had some decent luck on a site named spokeo. I took the liberty of looking her up on there, there are several different Victoria Browns who live in Texarkana, AR so you might have to check several of them until you find the proper one. The results of my search can be found by clicking on this link. Hope this answers your question, if not let me know!
Sep 15, 2011 | Cell Phones
How do I set up voice mail
Call services From your phone, you'll be able to access and change the settings of various call services for your phone.Contact your mobile operator to find out about the availability of call services. From the Home screen, press MENU and then tap Settings > Call. Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings Edit the call reject message, choose whether to open the message editor when you reject a call with a message, and choose whether to allow automatic saving of an unknown contact number when a call with that number ends.
Cell broadcast Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings Configure channels and language for cell broadcast messages.
Call forwarding Select how you want your phone to handle busy, unanswered, and unreachable calls. You can also set the call forwarding option for all incoming calls. Call barring settings Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Jun 28, 2011 | HTC Inspire 4G Smartphone
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
LG CHOCOLATE: identify phone number of incoming voicemail
try transferring the calls from ur mobile to the voicemail when u r not available....
in call settings u might have an option of forwarding the incoming call after so many particular number of rings... forward the calls to ur voicemail numbers using this and then u ll have the numbers in ur recieved calls list.
this might work but is only a temporary solution
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
My dad is using my old enV. whenever he wants to check his voicemail it calls my number. How can i fix this?
You need to change his Voicemail number. On a Nokia this is fixed by going to your Tools/Settings and selecting Voicemail, and changing the Voicemail number there. You can get your dad's Voicemail number by calling up the customercare. But if you remove your number from the assigned Voicemail number, it should fix your problem.
May 18, 2010 | LG enV VX9900 Cellular Phone
Unlocked moto v195 voicemail problems
I am not sure of your carrier, they all have different ways. The absolute way to access your voicemail is to call your own number. Call your number from your phone and it will automatically get you in to your voicemail..
Please give good rating..
Aug 27, 2009 | Motorola Mobility V195 Cellular Phone
I m getting a call from a unknown number ..he is bothering me and my family ..how can i get the name of that user...please help!!!
The person that left the "Solution #1" is incorrect. You can go to a website called Trapcall.com and set your phone up so that you can find out the number of the unknown caller. Unfortunately there is a small fee associated with this feature and it also disables your voicemail. I think it is worth it to have a solution for a troublesome caller.
Apr 13, 2009 | Cell Phones
I'm being harrassed by one caller
You can report the number to the authorities, or
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls
From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts <Except Contacts>. You'll still get the voicemails and notifications of who called, but unwanted callers will go right to voicemail and you can call them back whenever you are ready.
Feb 28, 2009 | Motorola Mobility RAZR V3
Where is the voice record key?
Voicemail
Your network stores the voicemail messages you receive. To listen to your messages, call your voicemail number.
Note: Your service provider may give you additional information about using voicemail.
The phone calls your voicemail phone number. If no
voicemail number is stored, your phone prompts you to
store a number
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 22, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
15 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
