Question about Danby DPAC8020 Air Conditioner
Is it normal for danby air conditioners to fill up with water every couple hours
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
koolbreezes
  • 540 Answers
SOURCE: Danby Air conditioner
Check out the co. website, for that unit and codes for troubling shootings! Thank-you-very-much!
Posted on Aug 27, 2008
  • 1070 Answers
SOURCE: danby portable air conditioner
https://www.danby.com/registration.php?ln=USE&
Go to this web site to register your product.
Posted on May 20, 2009
tebot
  • 15 Answers
SOURCE: Danby dpac120068 Air Condtioner, where does the
The hose goes into the empty tank or tray inside (if it's the drain hose like a garden hose). When the hot side of the system goes past there it evaporates the condensation dripping into it. If your talking about the big 4 inch hose, that goes out a window to get rid of the heat from the room.
Posted on Jul 28, 2009
SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
Posted on May 30, 2010
My DPAC10061 is filling up the water bucket to soon after emptying like 20 minutes. Why?
  1. DANBY DPAC10061 MANUAL Pdf Download. - ManualsLib
    www.manualslib.com > ... > Air Conditioner > DPAC10061
    View and Download DANBY DPAC10061 manual online. DPAC10061 Air Conditioner pdf manual download.
Aug 03, 2015 | Danby Heating & Cooling
Water tank fills up every 3hrs
The amount of water that is getting extracted from the air in the room is based on how humid the air is. The good news is your unit is really getting quite a bit of moisture out of the air and as such, is working well to cool your room.
It is working as designed. You may want to see if you can connect a hose to a drain port (if yours has that included) to let the unit room longer without the need to drain the condensate (water) every 3 or so hours.
Hope this helps and best regards!
Jul 31, 2009 | Danby DPAC8020 Air Conditioner
PI error messag every couple of hours
check the water level sensor's position. has it become loose from its mount and touching the water sooner then it should? it could be a probe or a float
Jul 27, 2009 | Danby DPAC8020 Air Conditioner
Everstar MPM 08CR BB4
Set it so it doesn't have to work as hard (i.e. higher temp) and it will generate less water.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Jun 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Danby DPAC 8099 Moisture Removal problem
If the dew point of the air in your place of operation is low you will not get moisture out of the air. Generally when the unit is first used it lowers the indoor humidity and you get a lot of moisture. Once things settle out the amount of moisture will decrease.
May 17, 2008 | Danby DPAC8099 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
18 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
