Question about Hoofien Iconic Notes and Lists
Can't unlock secure folder
Have set secure question but when trying to open does not allow to answer
Unable to open a new folder
maybe you don't have permissions for that folder.
To give you permission you have to do this:
Windows XP: ( But in windows 7 is similar)
First:
In windows explorer go to
Tools > Folder Options > View
Than scroll down at Advanced Settings for "Use simple file sharing (Recommended)
Uncheck that and click on OK.
Then go to that folder that you can't open and right-click on it and Properties.
Go to security and if you can put you user name in " Group or user names " click on Add and put your user name there and then check "ALLOW " from " FULL CONTROL "
then click ok.
If you can't click on Add , click on Advanced.
At Owner click on your user name or "administrator" , check "Replace owner on subcontainers and objects" and click Ok.
After you set you as owner you can repeat this:
(Only if you can't open that folder)
Go to security and if you can put you user name in " Group or user names " click on Add and put your user name there and then check "ALLOW " from " FULL CONTROL ".
Hope this helps if the problem is from permissions.
Nov 12, 2013 | Computers & Internet
Hello,my name Tairi Charlie Im having problem opening my email" -- because I forgot my identity answere
If you haven't logged into your Hotmail in some time and suspect you might be using the wrong password, click the "Forgot Your Password?" link on the Hotmail log-in page. On the next screen, follow the prompts to enter your email address and the given security verification code. Click "continue" and on the next screen, select the option that allows you to answer your pre-set security question. This is a question you supplied when you set up your Hotmail account. After correctly answering the question, you will be prompted to reset your password. Clear your browser history and temporary Internet folders if you are continually getting a "Page Cannot Be Displayed" message when you log in. The exact procedure for doing this depends on your operating system and browser. If you continue to get see this message, it could indicate a problem with the Hotmail server. Check the status of the network on a site like Down Right Now that reports server problems on popular sites. Submit a support request on the Windows Live page. On the Windows Live site, select "Hotmail" under "Standard Services." A search screen will open that will allow you to check out a variety of Hotmail related support topics. At the bottom of that screen, choose "get more help" and then "support." A support form will open for you to complete and submit to the Hotmail team. You will receive an answer within 24 hours. Note that you will need a second email account that you can access so that the Hotmail support staff can send you your answer. also you might try this link http://windows.microsoft.com/en-AU/windows/outlook/account-temporarily-blocked
Feb 08, 2013 | Microsoft Windows 7 Ultimate for PC
When i try to send,copy into or delete anything in the flash a massage appears saying " this disk is write protected remove the write protection or use another disk".
maybe your flash has switch for write protection, try to switch the lock to unlock, if there is no switch try to remove write protected profile from your flash.
1. open folder option then uncheck 'use simple file sharing'.
2. right click your flash then choose sharing and security.
3. choose security tab, u will see like this:
4. check allow full control. OK. then its done.
hope this useful, regard riayn.
Mar 30, 2011 | Computers & Internet
Target folder not accessible.
Perform the steps mentioned in the below article.
http://support.microsoft.com/kb/810881
Also, try this:
CAUSE
This issue may occur if the folder that you cannot open was created on an NTFS file system volume by using a previous installation of Windows, and then installing Windows XP. This issue may occur although you enter the correct user name and password. This issue occurs because the security ID for the user has changed. Although you use the same user name and password, your security ID no longer matches the security ID of the owner of the folder that you cannot open.
For example, although you use the same user name and password, you may no longer have permission to open the folder after you complete the following steps:
1. Before you install Windows XP Professional, you change the actual location, or target location, of the My Documents folder to another volume.
2. You format the primary partition.
3. You install Windows XP Professional.
RESOLUTION
To resolve this issue, you must turn off Simple File Sharing, and then take ownership of the folder:
1. Turn off Simple File Sharing:
a. Click Start, and then click My Computer.
b. On the Tools menu, click Folder Options, and then click the View tab.
c. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
2. Right-click the folder that you want to take ownership of, and then click Properties.
3. Click the Security tab, and then click OK on the Security message, if one appears.
4. Click Advanced, and then click the Owner tab.
In the Name list, click your user name, Administrator if you are logged in as Administrator, or click the Administrators group.
If you want to take ownership of the contents of that folder, click to select the Replace owner on subcontainers and objects check box.
6. Click OK.
You may receive the following error message, where Folder is the name of the folder that you want to take ownership of:
You do not have permission to read the contents of directory Folder. Do you want to replace the directory permissions with permissions granting you Full Control? All permissions will be replaced if you press Yes.
7. Click Yes.
Click OK, and then reapply the permissions and security settings that you want for the folder and the folder contents.
Also, try to create a folder in external Hard Drive and then try to back up the data.
Jun 25, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
I dont know what the heck is up with my computer. Previously, just yesterday in fact, I could access all my D: Drives Folder, but today, when I accidently dragged (lets name them folder a and b), Folder A...
This sounds a lot like something has taken over administrative rights to your computer, and limiting your access to your own folders. Try running Malwarebytes anti-malware to see if you have a trojan, rootkit or malware on your PC then try this program called unlocker1.8.7 to see if it will unlock the folder and give you permission to open it.
Apr 05, 2010 | Microsoft Windows XP Home Edition
My Nokia 6020 is 'locked' with 'Opening Folder'
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://europe.nokia.com/get-support-and-software/product-support/nokia-6020
Keypad lock (keyguard) from page 29 in your manual:
To prevent the keys from being accidentally pressed, select Menu, and press *
within 3.5 seconds to lock the keypad.
To unlock the keypad, select Unlock, and press *.
To answer a call when the keyguard is on, press the call key. When you end or reject the call, the keypad automatically locks.
Security code from page 17 in your manual:
The security code (5 to 10 digits) helps to protect your phone against
unauthorized use. The preset code is 12345. To change the code and set the phone to request the code, see Security p. 80.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Nokia Cell Phones
I can't hide my drives even i navigate the gpedit
you can't hide the drive, you can share or not share. However, you can hide and un-hide folder and files. go to the properties of the that folder or file, select hide.
if you login or any one else login as you, they will see the folder or file as a "masked" not hidden.
it will be hidden, when who ever login as themselves.
the other thing you can do is to set the security on the drive, folder or file via security setting. if you don't allow certain individual to access the drive, folder or file. this has to be done via local administrator login.
this is more secured. the individual require password to gain access to that area.
Nov 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
A1200 motorola cell phone password lock down
Your phone’s four-digit unlock code is originally set to 1234, which you already tried. However, the six-digit security code is originally set to 000000.
At the "Enter Unlock Code" prompt, try tapping the button with three horizontal bars to open the unlock code bypass screen. Enter your security code (which should be 000000 unless you changed it), then tap OK to submit the security code.
This might allow you to change your unlock code.
Jul 14, 2008 | Motorola Mobility A1200
Unlock code
See if there is a number on the box,
or on the back of your i-pod.
Hope this helps if
it is any use.
Jun 17, 2008 | Apple iPod classic MP3 Player
Samasung X820-Password
samsung x820 has been locked with security code.to open the security code what is the procedure
May 28, 2008 | Samsung X820 Cellular Phone
Hoofien Iconic Notes and Lists Logo
90 people viewed this question
Top Hoofien Apps Experts
Erin Wood
Erin Wood
Are you a Hoofien App Expert? Answer questions, earn points and help others
