Question about Lenovo X201 520M 2GB/320 BT F C W7-32 - 3680PKU PC Desktop
Yellow exclamation mark in network tray - Lenovo X201 520M 2GB/320 BT F C W7-32 - 3680PKU PC Desktop
    Problem Solver:
  • 13 Answers
Ur connection is Limited . go to open network and sharing centre and click Local area conection selcet properties and selcet TCP/IP v4 ang give corect ip address
Posted on Aug 17, 2015
Device\NTPNP_PCI0027
Troubleshooting :
Cannot access internet in OS using onboard network card bg-country_outline_top.png bg-country_outline_bottom.png Solution
1. Please check the LAN settings in BIOS.
2. Install a fresh OS and the motherboard driver, network card driver in support CD or downloaded from official website.
3. If the network card is not recognized in Device Manager, please contact reseller (service center) for tests.
4. If the network card is recognized in Device Manager, please do some troubleshooting as the following steps:
4.1. If there is yellow question mark or exclamation mark before the network card, please re-install OS and drivers. If the problem persists, please contact reseller (service center) for tests.
4.2. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection, the network cable is shown as "un-plugged(X)", please check network cable/router/switch/modem/other network peripherals and network port, or plug network cable to other system for test. If the problem persists, use another computer in the same network environment to check if it can access internet. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable.
4.3. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is disabled (grey), please enable(right click and choose "Enable") it for a test. If the problem persists, please turn off firewall, search and kill virus, reinstall OS and drivers. If the problem still exists, please contact reseller (service center) for tests.
4.4. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is shown as "Limited or no connectivity" (yellow exclamation mark)", please do some troubleshooting as the following steps:
4.4.1. Right click and choose "repair"
4.4.2. Unplug and re-plug the network cable
4.4.3. Re-connect the network or access IP
4.4.4. Restart
4.4.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.4.6. Skip router and connected to Modem directly
4.4.7. Turn off other computers in the same network to avoid IP conflict
4.5. If there is no yellow question mark or exclamation mark before the network card, and there is no abnormal situation in Control Panel/Network Connections/Local Area Connection, please do some troubleshooting as the following steps:
4.5.1. Try to access IP or Static IP automatically
4.5.2. Unplug and re-plug the network cable
4.5.3. Re-connect the network or access IP
4.5.4. Restart
4.5.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.5.6. Turn off firewall, search and kill the virus, reinstall OS and drivers
4.5.7. Check MAC address ( You could follow the commands: " Start"-" All Programs"-" Run", please input " cmd", after that you could input " ipconfig/all" to check MAC address)
4.5.8. If possible, use another computer in the same network environment to check if it can access internet
a. If the network connection is OK in another system, please contact reseller (service center) for tests
b. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable
Mar 03, 2014 | ASUS SABERTOOTH Z77 LGA1155/ IntelZ77/...
You plug a network cable into the motherboard (E219542) and the light glows yellow. What does this mean?
this might be the driver
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
if you need more help with this posta reply
hope this helps
Oct 11, 2012 | Dell Computers & Internet
As of today I cannot connect to ebay, all was fine until now and I connect to any other website, what do I do?
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
Nov 19, 2011 | eBay Auctions
Just got a wireless modem from telstra. now the computer is making static noise?
hope this helps you
Oct 09, 2011 | Dell WL6000 Computer Speakers
Connect via wireless router, but when i click on internet explorer it says internet explorer cannot display webpage
this could be a driver problem or it might be firewalled
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps
Sep 18, 2011 | Computers & Internet
Lan card driver problame
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don
Jul 14, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
After formatting the pc, got no connection on my internet. needs LAN driver E2180 @ 2.00GHz
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
Apr 29, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
My computer sound is not working
first off, is the driver properly installed?
To verify this, go to
(Windowx XP\Vista\7)
Control Panel
System
Device Manager\hardware
Sound and Video Controllers
Look for yellow exclamation mark, or a red x under the sound and video game options
if you see either marks, right click on the device in question and look for 'update driver', or enable device.
If there are no marks (yellow exclamation, or red x) then the sound card is likely installed and is just muted.
look in the system tray for a speaker icon, right click on it, look for a unmute option, or trey raising the volume
Nov 08, 2010 | Computers & Internet
USB
The yellow mark next to the Universal Bus indicates that there is some driver issue with one of the driver for your USB devices. You can try right clicking on the yellow exclamation mark, remove / uninstall the device and then click on Scan for hardware changes from Action menu. This may help in reinstalling the device.
Regarding your network card you can install in the available PCI slot regardless of the yellow exclamation mark next to universal bus.
Hope you find this solution helpful.
Please do not forget to leave feedback or ratings.
Thank you for choosing Fixya.
Dec 18, 2009 | Dell OptiPlex GX260 PC Desktop
Yellow exclamation mark over the network adapter- 6To4 adapter. When I uninstalled and restarted my computer the adapter was not reinstalled. Sony laptop with Vista 32 OS.
the yellow exclamation mark indicates that the driver is not installed... run the installation disk once again install the adapter .. if unable to install with cd then, right click on the adapter from device manager and click update driver and manually update the driver ... it should work
Apr 16, 2009 | Packard Bell 1580509280 Network Adapter
Lenovo X201 520M 2GB/320 BT F C W7-32 - 3680PKU PC Desktop Logo
63 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
