Question about Nelson L R 56610 Electronic Water Timer
A Nelson controller won't accept programming commands
My Nelson controller for my drip system was cutting off watering after 3 minutes even though it was set to water for 60 minutes. I cleared the controller using the commands in the product manual. Now no matter what I type in, the controller will not accept any entries. It is ''stuck'' on Prg with numbers indicating the sequence of the entry, like ''time'', ''date'', etc. how can I get the flashing numbers back to enter program values?????. I also changed the alkaline batteries for the unit. The unit is a Nelson Turf EZ Pro Jr 8300 model.
Where is the reset button located on my Nelson Turf Pro Jr. 8300
Posted on Jul 29, 2012
  • Dave Belcourt Sep 08, 2013
    OK, I did a bit more researching and looking at the innards of my 8300 and I DID find a "Reset." It's not a button, but looking at the circuit board, just below the AA batteries... look at the very top right hand corner of the board that is visible. There are two silver terminals up there and right below the terminals, it says (in print too small for my tired old eyes to read) "Reset." You take a common (flat bladeed) screwdriver and short across those two terminals. That should reset your unit to factory default settings. Then you'll probably have to reprogram your start times, run times, zones, schedule, and all of that. Good luck! I hope that does the trick for you.
    President:
  • 1,723 Answers
Look for a 'master reset' in the manual. This should put everything back to 'default setting'. Then start over in your programming. Don't forget to save after you program your parameters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
  • Joy Harris Aug 26, 2013
    That did not work.
    New Friend:
    Problem Solver:
  • 10 Answers
I don't think there is a reset button on the controller. Try removing all of the AA batteries from inside the unit for a few seconds then re-inserting them... or if they might be running out of juice, replace them with fresh batteries. That should reset things for you. Or, maybe not.
Posted on Sep 07, 2013
We have a Nelson drip timer unit that was made in 2/10/05. It has 3 programs with dials to set for time and programs . It also has a 9 volt battery attachment on it. My husband says that we need a ne
These simple systems cannot handle the back pressure of the water, seals are deteriorating try cleaning unit in dish water of bircarb soda
Feb 16, 2014 | Nelson Garden
Nelson water timer instructions
Have you tried the www.nelsonirrigation.com
Or your local hardware
May 25, 2013 | Nelson 2 in 1 Pre-Set Water Timer 56606
Water won't drain and then dishwasher won't turn on
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Jul 05, 2012 | De Dietrich 18 in. VZ9456 Built-In...
Miele 5065 descale program will not complete
Sounds like you need to get into the programming mode menu and reset it. I have a Miele CVA 4085 built-in coffee maker which had a similar problem to this and other problems where it gets locked into a state where it demands you empty the drip tray even though it is empty. In my case it was at the end of a cleaning cycle and refused to go on. Cutting power and restarting always had it return to the same state: Cleaning, empty drip tray.
I cleaned the contacts on the drip tray and at the back using the nail file, still nothing. Then I found a post on how to get into the programming menu, which on the CVA 4085 is this:
  1. Open the door and switch off the power with the rocker switch on the top left.Wait at least 5 seconds.
  2. Switch the rocker on then VERY QUICKLY close the door and hold the clear button for 5 seconds.
  3. With your other finger touch the ON button then pull both fingers away at the same time.
  4. Do 5 rapid presses of the clear button but hold your finger down on the last press and keep holding it down until the programming menu comes up.
  5. Do not press the reset button that you see at the top of the menu (unless your German is quite good or you have access to Google Translate).
  6. Scroll down until you find the reset cleaning button and select it. Once you have confirmed you can then exit programming mode by powering off.
It took me quite a while to get to this point, but at least I can now recognize the German word for drip tray.
May 22, 2012 | Miele Coffee Makers & Espresso Machines
I have a Atwood dsi water heater that after hot it wil keep lighting run a few minute and shut off and it will keep doing this but some times off for hours normal. I changed thermostats no difference
Don't forget pressure relief valve as well. Small drip is acceptable though. Double check by-pass valves are in proper position as well.
Thermostat if working properly would have to sense (feel) cooler water at it's location in order to re-ignite system, which makes me think, cooler water is circulating through there somehow.
Dec 14, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Can you give me a simple way to program my system? I have two different zones, and would like to run each zone 30 minutes Mondays and Fridays. Do I set zone one on A and zone 2 on B. What about C?
Do you have the manual? Just program two zones for the 'A' program. Don't need B and C. Set the time, date and all that, then set the days you want to water to 'On' . Then set the zones you are using like 1 and 2 and put in the amount of time you want it to water, like 30 minutes. That's all there is to it! Let me know... I'll help you.
Jun 30, 2009 | Nelson L R 56610 Electronic Water Timer
Nelson L R  56610 Electronic Water Timer Logo
2,468 people viewed this question
Top Nelson Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Hippy_dd
Are you a Nelson Hardware and Accessory Expert? Answer questions, earn points and help others
