Question about Shaw Robert RS-9420 Thermostat
How do I stop the therostat from reading high?
R 1 running hot with water temprature light comming on at high speed
check coolant level , elec fan , therostat and if engine is boiling and bubbling wen at running temp ! if ok then mite be a sensor ! P...
Dec 22, 2013 | 2007 Yamaha YZF-R1
Therostat is reading celsius how do i change to farenheit
On a case like this, it's impossible to switch from Celsius to Fahrenheit. Sorry.
Feb 24, 2011 | Power Up 5511 (TC3J-4032 P) ATX Mid-Tower...
Overheating fitted new water pump and therostat
if its a high milage vehicle it might be the radiator. around 200.00 to replace. it could also be a head gasket. check to see if you are loosing coolent. last but not least the 5.0 (318) had problems with leaks under the intake. it would loose pressure and cause heating problems. again look for coolant loss.
Nov 30, 2010 | 1999 Jeep Grand Cherokee
What is the recommended thermostat temp replacement for 1993 buick skylark 3.3 v6? 180? 195? engine runs cold, never reaches optimum operating temp.
195 IS THE ORIGINAL THEROSTAT THE ONLY THING A T-STAT DOES FOR YOU IS FOR HEAT IN THE WINTER THE HIGH THE TEMP THE BETTER THE HEAT IN THE CAR
Oct 16, 2010 | 1996 Buick Skylark
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
I have a 1991 jeep cherokee sport with a 4.0 high output engine i put a new radarator new head gasket new head new water pump and new cluch fan also new therostate i can,t get the therostat housing to seal...
try aviation gasket maker / messy but stops leaks .make sure you have all surfaces clean no debris stuck on them and the right thermostat that fits and the proper gaskets or o ring and a little avaition gasket glue should cure the problem . leaks require patience :) gl
Jan 06, 2009 | 1993 Jeep Cherokee Country
Therostat in rv doesnt work right
Suggest you replace it.  If the unit runs on 12volts, a battery powered unit is fine.  Just connect the wiring to the appropriate terminals.
Nov 15, 2008 | Heating & Cooling
Shaw Robert  RS-9420 Thermostat Logo
54 people viewed this question
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
