Question about Gaggenau AH 400-731 Kitchen Hood
Why does my switch not turn off my light - Gaggenau AH 400-731 Kitchen Hood
My 1992 Dodge dynasty turn signal lights and brake lights aren't working can u help
It's probably a bad turn signal switch, since the brake lights are wired in with the turn switch.
If you have a 3rd brake light, the high mounted one in the rear window, this light is separate from the brake lights that go through the turn switch. If your high mount brake light comes on, when brakes are pressed, then brake switch is good and probably a bad turn signal switch. Of course if you have a voltmeter or test light, you could test for power in and power out from the turn switch connector, to help you find the problem.
Oct 23, 2016 | 1992 Dodge Dynasty
Third eye works no rear signal or brake lights
The high mount brake light gets its own signal from the brake light switch (on the brake pedal). Or at least the wire leaving the brake light switch will splice, one wire to the high mount brake light, and the other for the rear brake lights is routed through the turn signal switch, and coordinated there with the turn signal wires to the rear brake lights. The brake wires and turn signal wires share the same wire, and same filament in the bulbs. It is kind of complicated, but brakes applied with no turn signal, brake light wire goes from brake light switch through the turn switch and out to the bulbs. If brakes applied with turning signal, non blinking brake light wire goes from turn switch to rear light, while the turning signal wire will go through the flasher relay, and then to the rear light to cause blinking.
I hope that makes sense. It appears the problem may be in the turn signal switch for both the turn signals and the rear brake lights.
Mar 14, 2015 | 2007 Dodge Ram 3500 Quad Cab Laramie
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 differemt locations?
One of the switches needs to be a 4-way then the PIR will act as any other switch. The downfall is if the lights are on and motion is sensed they will turn off.
My preference is to connect the contacts of the security device across the travelers of the three way circuit. The travelers are probably the red and black in the three conductor cable. When motion is detected the lights will turn on regardless of the settings of the three way switches then after timeout they will turn off. If they are turned on with one of the three way switches nothing will happen when the motion detector turns on except you cannot turn the lights off until the security device has turned off.
I hope this helps. The motion contacts need to be isolated from the motion detector power.
Feb 20, 2014 | Electrical Supplies
Adjust brake light switch
The brake light wire leaves the brake switch and goes into the turn signal switch. They often share the same wire: the rear turn signals and the brake lights. When turning, that side is routed through the turn flasher, but you get a steady brake light on the other side.
So you have power to the brake switch. Pull apart the connector for the turn signal switch, and see if you have power in on the brake wire (with brake depressed of course) going into the turn switch. If you have power in, plug the connector together, and see if you can backprobe the connector with test light or voltmeter, looking for power out to the rear brake lights. If power in, but no power out, the turn switch is probably bad.
Dec 31, 2013 | Ford E-150 Cars & Trucks
Signal lights dont work and want to know where the fog light switch is at
With the switch in sidelight or dip
position, pull the switch to its first
position to turn on the front fog lights.
Pushing the switch in or turning it to OFF
or AUTO will turn off the front fog lights (this is for the front)
With the switch in any position except
OFF or AUTO, pull the switch to its
second position to turn on the rear fog
lights. This will also turn on the front fog
lights unless main beam is selected.
or AUTO will turn off the rear fog lights (this is for the rear)
Exterior lighting
Exterior lighting switch
A. OFF.
B. Side (parking) lights.
C. Headlights.
D. Auto.
E. Front fog lights.
F. Rear fog lights.
It is the round knob nest to the steering colume
Aug 18, 2011 | 2003 Jaguar X-Type
What causes the brake lights not come on,but allow 3rd mount light to come on? i've checked the bulbs,sockets,fuses. now i'm stumped.
THOSE LIGHTS ARE ON 2 DIFFERENT CIRCUITS. ONE WHITE WIRE COMING OUT OF THE BRAKE LIGHT SWITCH GOES TO THE CENTER BRAKE LIGHT. THE OTHER WHITE WIRE GOES FROM THE BRAKE LIGHT SWITCH TO & THROUGH THE TURN SIGNAL SWITCH SO THE LIGHTS CAN BE USED AS BRAKE LIGHTS OR TURN LIGHTS. THE BRAKE LIGHT SWITCH IS GOOD BECAUSE THE CENTER BRAKE LIGHT IS WORKING. IT IS A BAD WIRE { WHITE } FROM THE BRAKE LIGHT SWITCH TO THE TURN SIGNAL SWITCH OR A BAD TURN SIGNAL SWITCH.
Jan 17, 2011 | Buick Riviera Cars & Trucks
Hwere is the switch for courtesy lights on floor?
The older cars have a dimmer switch built into the headlight switch panel that turns on and off the interior lights and the dash lights , in some cases it is the pull headlight switch light that one can turn up and down for bright and dim to off position.'There may also be a single thumb turn or twist turn light switch that controls the interior lights located on or around the headlight panel switch.
Jun 06, 2010 | 1996 Oldsmobile Cutlass Ciera
95' Buick regal, 3rd brake light works, tail lights work, turn signals work, stoplight switch seems to work ie 3rd brake light working, fuse is ok, changed bulbs, but no rear brake lights.
If the third brake light works and the regular ones don't, it is most likely a bad turn signal (multifunction) switch. The switch is able to kill the brakes lights to run the turn signals, and in rare circumstances does this. I've seen it several times. It could also be wiring, especially near the turn signal switch, but it is usually the switch.
Nov 25, 2009 | 1995 Buick Regal
No brake lights or turn signals head lights and turns work on the front and i have parking lights all around and all fuses are good
It is most likely your brake light switch. The wiring from the brake light switch goes to the turn signal switch. When the turn signal switch is centered both brake lights are connected, unless the switch is faulty. When the switch is to the left only the right light is connected to the brake light switch and vice versa. A bad switch can cause all kinds of problems with the brake lights as well as the turn signals.
To replace, locate the brake light switch at the top of the brake pedal (on the mounting bracket). Unplug the connector. Loosen the locking nut and remove the switch. Install the switch and adjust the height so the switch activates at the right position. Reconnect the connector and check for proper function.
Oct 18, 2009 | 2000 Chevrolet Cavalier
Gaggenau AH 400-731 Kitchen Hood Logo
67 people viewed this question
Top Gaggenau Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Gaggenau Kitchen Range Expert? Answer questions, earn points and help others
