Question about Water Heaters
Hatco Model c-21: How do you delime unit? - Water Heaters
  • 332 Answers
Is there a way to disconnect the supply and run vinager thru the out let backwards to the supply with a hose attachment,,
Posted on Jun 24, 2009
How do I erase error code 1l
1L is scale build-up in heat exchanger: delime tankless unit:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#delime
If error code will not reset afterwards, then holding both arrow buttons down on remote might reset error code.
Models have changed since this pdf was posted in 2008
http://hometips.me/Tls/Clear-fault-history-Service-manual-2008.pdf
If error does not clear, then call Rheem and expect them to try to sell you a service call.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 07, 2014 | Water Heaters
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
My control unit keeps alternating between 120 and IL. Cannot find code IL
Before calling service technican, copy following links for general troubleshoot resources and error codes, and manusls, and Rheem contact information:
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Error IL usually means delime the unit.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Read your product manual for yearly/monthly maintenance schedule.
Tankless are maintenance heavy and must be delimed each year.
Deliming using white vinegar take about 1 hour, and will not restore full efficiency to unit.
Tankless have the habit of forming lime deposits inside the heat exchanger, even with softened water.
Tankless cannot be exposed to more than 11 grains hardness in water.
Don't buy a tankless next time.
Read the manual first.
Aug 09, 2012 | Rheem Rtg53xn Natural Gas Tankless Water...
Where do I find model number or serial number?I turned off main water valve to replace a leaking pipe and now I can't turn on the water heater. How do I do it?
1) You posted under Bosch tankless water heater.
There should be a nameplate on front of unit or located where you can see it.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
2) Replacing water valve probably loosened build-up inside pipe that lodged in water heater or inside elbow just beneath tankless unit.
If water flow is stopped or slowed, tankless will not operate.
3) Remove pipes and see if clog can be flushed.
4) Also U-tupe search "delime tankless water heater" and technique used for deliming will be good way to clear out tankless clog and sediment.
Your tankless should be delimed each year anyway.
5) Read your manual cover to cover, and see words 'troubleshoot' and 'maintenance' are used throughout manual. Get acquainted with your water heater and manual, because tankless are maintenance heavy, especially if conditions are not optimal and as unit ages.
6) All costs are energy. Install tank type water heater for ez do-it-yourself repairs and maintenance.
Tank type work under all types of adverse conditions and water pressures and water conditions, and even withstand sediment build-up for several years. Of course tank-type pipes can clog too.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | Bosch PowerStar AE125 AE125 Whole House...
Have model C36 replaced t-stat relief valve and pressure reducing valve. Blowes off a temp over 170.
I think it is doing what it was designed to do. I think the water should not get to 170 degrees.
Is this a residential water heater?
Gary
Feb 04, 2011 | Hatco Corporation Water Heaters
Not working
It has kick the breaker in the fuse box or it has a reset on the unit its self,reset it.if that does not fix the problem,you will have to replace the unit with a new one.
Jan 22, 2011 | Hatco Compact Electric Booster Water...
Does this unit need pre heated water?
yes the unit will need to be fed with hot water to work correctly.It has a rise if you want your rinse 180 then you will need to feed the booster with hotter water if fed with cold water it will not keep up under high demand usage.
Jan 16, 2011 | Hatco Compact Electric Booster Water...
We need a new thermostat for a Hatco booster heater dishwasher
Try Rick at Restaurant Parts and More in Ohio. Have model and serial number. He's pretty good at getting stuff like that and he reasonable on prices. I'm in Ga. and I have a 3 day turn around on anything I order from him. He's a straight shooter too. If he can't help you he'll try to find some one who can.
Feb 26, 2009 | Hatco Corporation Compact Electric Booster...
Hatco c 12
hi my name is mark. hi limit safety has a red reset button follow link to instructions to adjust rinse temp to dishmachine. i hope you are not using this unit as a home water heater. http://www.hatcocorp.com/productinfo.nsf/AllDocumentationAttachments/14B2C666CC6F114286257107005AC28E/$File/EBOOSTERM-0406.pdf?OpenElement
Feb 09, 2009 | Hatco Corporation Compact Electric Booster...
With the hatco booster water for automatic dish machine
Under normal and regular operation Hatco recommends that the unit be turned on at all times.
If the booster heater will not be used for an extended period of time or will be exposed to freezing conditions it should be drained to prevent damage to the unit.
Jan 28, 2009 | Water Heaters
Water Heaters Logo
106 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
