Question about Akai Computers & Internet
Wht does akai gps12 does - Akai Computers & Internet
Need replacement remote control 5.1 Akai HHT-006
This company or eBay
AKAI TV Remote Controls ' AKAI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/AKAI/Remote-Controls/
  1. Cached
ReplacementRemotes.com offers AKAI remote controls for sale online including remote controls for TV, DVD Player, TV/DVD Combo and many more. Missing: 5.1
Akai TV Remote Controls ' eBay
www.ebay.com > ... > Akai TV Remote Controls
  1. Cached
  2. Similar
AKAI KC02-A2 OEM Replacement TV Remote (LCT3701AD,LCT3201TD,LCT2701AD) ... Akai Samsung TV Remote Control Replacement BP59-00069A. $9.99. Missing: 5.1
replacement remote control 5 1 Akai HHT 006 Google Search
Apr 14, 2017 | Akai Televison & Video
Color code wiring for 2007 dodge 3500 4x4 tail lights and reverse light
Left
TAIL/STOP/TURN lamp: WHT/DK GRN
TAIL/TURN lamp: WHT/YEL
BACK-UP lamp: WHT/LT GRN
Right
TAIL/STOP/TURN lamp: WHT/YEL
TAIL/TURN lamp: WHT/GRY
Sep 16, 2016 | Dodge Ram 3500 Cars & Trucks
2008 ford explorer stereo wiring diagram
The audio control module (ACM) has a pair of stereo in inputs. The right channel is BLU/GRN + and WHT/GRN -; the left chaanel is YEL/GRN + and BLU -.
LF speaker: WHT + and WHT/BRN -; RF speaker: WHT/VIO + and WHT/ORG -; LR speaker: WHT/GRN + and BRN/YEL -; RR speaker: BRN/WHT + and BRN/BLU -
Sep 30, 2012 | 2008 Ford Explorer 2WD
How do i work gps12 garland
Hi!
Here's the link for your owner's manual AND the addendum for your Garmin GPS12:
https://buy.garmin.com/support/manuals/manuals.htm?partNo=010-00146-00
Hope this helps you out.
Good Luck!
Jan 23, 2011 | GPS
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
Color wireing codes for DEH-P730 cd player
red - acc power
yel- battery power
blk - ground
blu - power antenna out
blu/wht - amp remote out
wht - left front +
wht/blk- left front -
gry- right front +
gry/wht- right front -
grn- left rear +
grn/wht- left rear -
prpl- right rear +
prpl/wht- right rear -
Aug 23, 2009 | iLO CA3000V CD Player
Garmin GPS 12 seems to be a few hundred yards out!
Go into your device and pull up the setup section. There should be a selection that needs to be checked called WAAS. When that is selected your accuracy should be +- 3 meters if I remember correctly. At any rate it will be much more accurate.
Apr 02, 2009 | Garmin GPS 12 GPS Receiver
Upload not present message Garmin GPS12
Hi...once i was asked the same problem!....and we couldn't do anything...i think you lucky because...the one who asked me about the same problem crashed his software forever...i recommend you to go for the warranty...and not to attempt any update...
Aug 23, 2008 | Sport & Outdoor - Others
GPS 12 "upload not present"
I have a Garmin GPS 12, which has worked perfectly over the last 10 years until a few days ago. It was on and working fine, I marked a waypoint, turned it off and put it in my pocket. 45 minutes later I pulled it out and when I tried to turn it on it only showed the message "UPLOAD NOT PRESENT". Nothing I did would get it to show me anything different (I tried all kinds of button sequences...holding some down for many seconds, pressing multiple at the same time, etc.). The only thing it would do was turn on and show me that message, or turn off. I called Garmin and they said they could repair it, but that would require shipping it to them. They said it would cost $59 (which included the repair and shipping back to me, but I was responsible for whatever it cost to ship it to them). I asked if they would be able to save my routes and waypoints if they "repair" it, but they couldn't guarantee that. I told them that I heard "reloading the firmware" or "uploading the newest update" might fix it AND keep my routes and waypoints. They told me that might work. I didn't have the PC interface cable that was necessary in order to connect it to my computer to update it, so I asked them what it would cost to buy one from them. They said it would be $38.09 through them, but that I could get it cheaper on the Internet (part # 010-10141-00). Then they said they actually may have some of them sitting around in a box somewhere (I'm assuming they meant used cables). They checked around and found one and shipped it to me at no charge! It arrived in a couple days. Then I just plugged it into one of the serial ports in the back of my computer, plugged the other end into the GPS and turned it on, went to Garmin's website: http://www8.garmin.com/products/gps12/download.html and downloaded version 4.60. I'm not sure what version was on my GPS originally (I obviously couldn't check anymore since it wasn't working), but the user manual that came with it said "Software Version 4.03 or above". It asked me to unzip the downloaded files and stored them on my hard drive at C:garmin. I opened up the file named 460_UPDT.TXT and followed the directions listed there (which are slightly different from the directions listed on the website's update page). One of the steps said to "Turn on your GPS and ensure the Serial Data Format is set to "GARMIN". You can find this setting in Setup Menu -> Interface." I couldn't do this since mine only displayed the message "UPLOAD NOT PRESENT", so I just ignored this step. I opened up the file named UPDATER.EXE and had it "auto-detect" when it asked me which serial port I used. The message on the GPS screen changed to "UPLOAD IN PROGRESS" and it only took about 4 minutes until the upload was done. The GPS screen then changed to the start-up screen where it acquires satellites and asked me to enter my country and state. Everything seems to be back to normal and all my routes and waypoints are still there. Even better, it didn't cost me anything but time.
May 31, 2008 | Garmin GPS 12 GPS Receiver
Garmin problem
I think I found the solution to everyones problem of "upload not present" message on the Garmin GPS12** when trying to update the Firmware. I'm really busy - just picked up my daughter from the airport and a million things to do. I will post again in detail maybe later today-tonight.
Mike
Computers & Internet Logo
32 people viewed this question
Top Akai Computers & Internet Experts
Michael Vincent Cruz
David Payne
David Payne
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
