Question about Canon EOS Rebel G-II 35mm SLR Camera
Command dial not working on n65 - Canon EOS Rebel G-II 35mm SLR Camera
  • 538 Answers
Remove top cover. Check Mode Switch position
Posted on Jul 31, 2014
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
I have a nikon n65 and there is a blinking F- - what does that mean?
The F-- indicates that the camera isn't communicating with the lens. If you have an old mechanical lens with no electronics, you'll have to set the camera to the Manual exposure mode (turn the mode dial to M) and shoot without any help from the camera's light meter.
If you're using a newer AF lens with electronics, clean the electrical contacts on the back of the lens and in the mount on the camera body.
Jul 13, 2012 | Nikon N65 35mm SLR Camera
I have a nikon n65 with a broken film winder/ tightener, how do I fix?
If it is broken the way my EM was broken, it is not repairable. There is a working N65 body on E-bay right now for the buy it now price of $19.99: Nikon N65 Camera Body 35mm SLR
N65 shutter button failure
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
Jul 04, 2012 | Nikon N65 35mm SLR Camera
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
How can i turn the flash off of my nikon n65 camera?
In the PSAM modes the flash won't pop up on its own. In the AUTO and vari-program modes, you can set the flash mode by turning the command dial while pressing the flash sync mode button (marked with a lightning bolt symbol). Select Flash Cancel (lightning bolt in a circle with a slash through it).
If you need a manual, you can download one at
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Dec 22, 2010 | Nikon N65 35mm SLR Camera
What does fee mean ?
It means that you have fitted a lens which has a manual aperture control and have not turned the aperture ring to the smallest setting (highest number). The F65/N65 controls the aperture from the camera body instead, via the command wheel.
If this is not the answer, then the tiny switch at about the 7 o'clock position (as you look at the front of the body lens mount) which senses that the aperture has been set to minimum has either failed or has sheared off completely. If so, your camera is totally uneconomic to repair as it's easy enough to get perfectly good N65/N75 and similar models for nothing via your local Freecycle and Freegle groups.
Sep 20, 2010 | Nikon N65 35mm SLR Camera
Film display says FEE and will not take a picture. How do I fix it?
Your lens has an aperture ring, doesn't it? Turn it to its smallest aperture (largest f/number) and lock it if the lens has a lock. Adjust the aperture using the command dial on the body, not the ring on the lens.
Jan 20, 2010 | Nikon N65 QD 35mm SLR Camera
I can't see through the eyepiece of my new Nikon N65 too well
The lens needs to be an AF model. If pre AF or New digital AF-S then that is the problem.
Sep 24, 2009 | Nikon N65 35mm SLR Camera
Flashing letters in lens
Turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it there if it has a lock. You control the aperture through the command dial on the camera body, not the aperture ring on the lens.
Mar 10, 2008 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Canon EOS Rebel G-II 35mm SLR Camera Logo
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
