Question about Multitech Systems MultiModem II MT2834BL (354519)
Cannot connect to the internet
I am using an axssestel router to connect to the internet via a LAN cable. I have tried to connect on numerous occasions however it I cannot establish a connection. My service is not suspended or anything as my SP said however I still cannot connect. Please help
  • 11,896 Answers
First thing I would do is disconnect router cable and plugin for exactly 10 seconds and then plug it back it. This will remove static discharge from router that tend to build up on a normal basis.
If problem still persists, go to network settings, click repair.
You can also set up a home network with the connection wizard which I would use all the "recommended" or "automatic " settings.
I am sure one of these will work just fine for you
Posted on Jun 23, 2009
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
Tip
Wireless Router Security
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router via the wireless connection.
For the computers and laptops to connect to the Internet you need to connect the DSL or cable modem with a LAN cable to the WAN (Internet) port on the router.
on Dec 02, 2009 | Computers & Internet
What ports do i plug into to be able to use a Broad Band internet
Plug the lan cable from Modem to the Router Wan / Internet port. From Lan port ( Router) you can connect to switch or computer if you have any . Or connect computer via wireless.
That' all
Mar 25, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
My cable internet provider has provided me with an Ethernet cable which connects directly to my PC. My PC's MAC address is registered with the ISP. I use a PPPoE connection to access the internet with a...
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
Feb 04, 2011 | D-Link DIR-600 Router
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
    carry out the resetting of the dlink router
    then use lan cable to gain access to dlink router,
    set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
    if it has a built in wizard then just follow the on screen instructions
    you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
    and the your done. disconnect the laptop from wired connection and connect via wireless
    Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
    No wireless connection
    Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
    In the Address bar of Internet Explorer, just type the IP Address.
    Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
    Can't establish connection by cable
    Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
    Apr 11, 2010 | D-Link DIR-300 Wireless Router
    Netgear WGR614 router with USB Cable Modem
    When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
    Dec 18, 2009 | NetGear WGR614 Wireless Router
    Computers & Internet Logo
    55 people viewed this question
    Top Multitech Systems Computers & Internet Experts
    Vladimir Frolov
    Larry Fostano
    Larry Fostano
    Karen Gibson
    Level 1 Expert
    Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
