Question about Nordic Track Exercise & Fitness
How to adjust belt?
Belt is slipping off track while being used
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
If you are adjusting the walking belt that much (7 complete turns) it sounds like the drive belt the small rubber belt from the motor to the front roller is really loose. You should only have to adjust the walking belt 2-3 turns max... you do not want to prematurely stretch your walking belt!
Posted on May 14, 2014
3 Suggested Answers
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a Nordic Track Commercial 1300 eliptical that started slipping when we used it. We tightened the belt but it didn't help. What else could be wrong?
Step 1
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Step 2
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Step 3
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
sincerely. Merry Christmas.ernesto cuadra
Posted on Dec 19, 2011
Why does the belt slip forward when I run on it?
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Sep 15, 2015 | Exercise & Fitness
Belt keeps slipping on treadmill
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Belt has moved to the left
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension atreadmill beltwhen it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures forhow to tension a treadmill running belt.
  1. Adjust for no slippage of thetreadmill walking belton the front roller (Often referred to as the "Stomp Test")
  2. This procedure requires twobelt gauges or calipers
Mar 16, 2014 | Precor Exercise & Fitness
Adjusting the belt of the Precor 9.1
Mar 13, 2014 | Precor Exercise & Fitness
New running belt tracks to thr left
Feb 04, 2014 | Precor C962i Treadmill 220V
How do I tighten drive belt on precor 956i
Jan 04, 2014 | Precor 956i Experience Series Treadmill...
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Adjust belt side
Dec 19, 2013 | Precor 9.21 Treadmill
How do you adjusting the running belt on precor 9.1 treadmill
Mar 13, 2013 | Precor Exercise & Fitness
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
153 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
