Question about Goldstar WG5000 Air Conditioner
Lay side way - Goldstar WG5000 Air Conditioner
Can i lay my mini tower on its side
You can put it in any position that you would like. There is no effect to its performance when you lay it down, unless the CD player wont hold the disk.
Apr 01, 2014 | Acer Computers & Internet
GE model GTS22WCP can I lay it on it's side or back to transport?
it is not recommended to lay an appliance with a compressor, the reason is that the compressor oil will run to one side and the appliance will not function properly. i have heard that if laid down the make sure to stand the appliance upright for several days before plugging it in.
Aug 08, 2012 | GE GTS22WCP Top Freezer Refrigerator
We are going to purchase a fridge. Can we lay it on the side or back to transport it home without any problems
if the refrigerator is a new one it will be in a carton in order to protect it from scratching or having faulty .
On the carton you will see the description on it , just follow the instructions ,
But if the refrigerator does not comes with a carton you can lay it through it's side , that is the positions , because laying by the back side might break the gas pipe which will cause more damages to the refrigerator.
So lay it by it's side . Thanks and hope it help in solving the problem....
Jan 12, 2011 | Hotpoint Refrigerators
How to put the door back together correctly on a Maytag Range. Model #MGR5745ADW
I lay the door on a nice work table and lay in the insulation. I attach the handle or the base first depending on the model then lay on the new outer glass and attach the handle and top or the base. Then I carefully snap the sides on last. I like to attach the bottom plate fist if at all possible then lay in the insulation and glass then attach the top plate and handle, then snap the sides on. The hardest part is getting the sides on.
Apr 29, 2010 | Maytag 30" Self-Cleaning Freestanding Gas...
Can you lay a refrigerater down flat to transport it
Yes as long as the coils that carry the freon is located on the top side of the compressor when laying down. Look at the lines on the compressor. You should see 2 of them. 1 larger than the other. Imagine you are tilting the refrigerator. If the lines are on the right side you can it down on it's left side ok. If they are on the left side you lay the fridge down on it;s right side. Hope this helps.
Feb 13, 2010 | Refrigerators
Carry refrigerator laying down in an SUV
The reason that it is not recomended to lay a refrigerator down on it's side is because of the oils in the compressor.
When you lay the refrigerator down on it's side the oil can get into the lines and cause problems.
because you have already done so, stand the refrigerator back up and let it sit for 48 hrs and give it a try.
If you half to move a refrigeratror on its side, the best thing to do is inspcect the compressor and see witch side the main lines come out and lay the refrigeator on the oposit side as not to allow the oil to get in those lines.
Jan 11, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Is it ok to lay this computer on it's side?
Yes you can lay the computer on its side. With it facing towards you carefully lay it on it's right hand side and don't place anything heavy on it while it's on it's side.
Many Dells are designed to stand up or lay on their sides, it should be safe and won't cause you any trouble.
Regards.
Nov 24, 2009 | Gateway SX2800-01 PC Desktop
Can you lay a maytag on its side /back?
You can lay a refrigerator on its back. If you need to lay it on the sides, try not to do it in an angle greater than 20 degrees.
The user manual should indicate how to handle the appliance for moving and installation.
Aug 30, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Laying fridge on it's side?
Hi kelli Yes you can lay It down So that the compressor Is at the top. But when you stand It up again You must let It stand for a few hours before you turn It on ope this answers your question
Dec 15, 2008 | Kenmore Refrigerators
Moving a ref.
do not lay down ,,,, oil from compressor will get into the lines and mess up your system ,,, be safe and haul upright and wait 5 minutes after setting in place to plug it back up / larry
Dec 08, 2008 | Whirlpool ET6WSKXK Top Freezer...
Goldstar WG5000 Air Conditioner Logo
19 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
