Question about Soyo SY-7VBA133 Motherboard
Manual pc soyo sy 7vba 133 - Soyo SY-7VBA133 Motherboard
  • 17 Answers
SOURCE: SOYO SY-7VBA133U cannot adjust CPU speed
Flashing the bios is the best idea to start with. This will upgrade to the newest bios, which normally adds more features and fixes some bugs.
There is a small chance that this motherboard just doesn't support overclocking, but the majority of them do.
Below is the link to soyo's site and downloads for your model number. There was 4 or 5 bios updates. I would get the newest one.
http://www.soyo.com/content/Downloads/155/&c=28&p=48&l=English
Hope this helps
Posted on Mar 21, 2008
Kidyubyub
  • 143 Answers
SOURCE: Soyo SY-P4VDA-2AA2
This page has all the drivers and the manual for download:
http://www.soyo.com/content/Downloads/155/&c=27&p=5&l=English
Posted on May 16, 2008
colliewob
  • 781 Answers
SOURCE: manual e instrucciones
http://www.soyo.com/content/Technical_Support_Downloads/155
try the above site you may have to search for ti
Posted on Jul 30, 2008
dlundmark
  • 797 Answers
SOURCE: Soyo SY-K7VMP2 manual
To start you need to go to some of the links here and find the manual.
When I tried, the main site was not accessible. That can change for a number of reasons. The manual may be able to be found at other sites.
Hope you find it.
Since this board is over 7 years old (2002) as stated at the link above, it may be to your advantage to upgrade to a newer board.
Another thing which you will find is that the bios probably should be flashed to get the newest version for this board. Before going too far on this board, everything should be checked over visually. Such as the dust, the components and so on on the surface of the board. You will have to decide.
Posted on Aug 31, 2009
pacman869
  • 4 Answers
SOURCE: manual reset motherboard: Soyo SY-K7VME
Bios settings are retained by the Motherboard Battery in the CMOS. Disconnecting the battery clears CMOS and returns the settings to their original state. Typically this can be done by simply removing the CMOS battery and waiting about 15 seconds before reinserting and booting PC. Nowadays most Motherboard manufacturers supply a jumper to not only disconnect the battery but also ground the CMOS to effectively drain any residual power.
The instructions for your MB are found below. JP5 is located to the left of the battery and next to the PCI 2 slot on your MB. There is a Manual for your MB on this site and the MB layout can be found at
http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-5
Follow the steps below to clear the CMOS memory.
1. Clear the CMOS memory by momentarily shorting pin 2-3 on jumper JP5. Its white cap can easily identify this jumper.
2. Put the jumper back to 1-2 to allow writing of new data into the CMOS memory.
Posted on Jan 08, 2010
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
Jan 11, 2013 | Soyo SY-7VBA133 Motherboard
My engine dyno uses a Soyo sy-7vba 133u, it boots up sometimes, sometimes it won't. Can you repair it? Or have a source for a new one? Mike (714) 766-9275
Intermittent booting is probably due to bad capacitors on the mobo ( as long as you are sure the PSU is working). Failing capacitors manifest themselves usually by showing leakage or bulging. If you can locate any replacements, you could resolder them..
As to the replacement board, I have only seen one in the last year for sale on Ebay (tonight) and that was broken. Soyo went out of business a few years ago.. or were taken over..
Feb 08, 2011 | Soyo SY-7VBA133U Motherboard
Hola ; Tengo una pc con mother Soyo SY-7IWM/L Motherboard y necesito el manual o saber que cantidad de Ram soporta la Mother
Tengo una manual en ?ngles.
Aqu?: http://www.elhvb.com/mobokive/archive/Soyo/manual/686/m7iwml11.pdf
Pagina 22.
De Nada xD.
Sep 27, 2010 | Soyo SY-7IWM/L (SY-7IWM/LV1.0) Motherboard
Need motherboard manual for soyo sy-k7vem
soyo manual can be downloaded from web site soyo web typ in board then download manual jim
Feb 17, 2010 | Soyo SY-K7VME Motherboard
Necesito manual de sy-7vba133. Gracias a quien me pueda proporcionar.
Aqui esta el manual para el MB.
Esta in PDF
SY-7VBA 133
Si no tienes Adobe Reader, aqui esta para download.
Nov 16, 2009 | Soyo SY-7VBA133 Motherboard
Max ram for SY-K7VEM PRO
Two SDRAM DIMM sockets support up to 512MB
168-pin PC133/PC100 non-ECC, unbufferred SDRAM memory
This is what your M/board can use in memory
Aug 20, 2008 | Soyo Sy-K7Vem-Pro Motherboard
Soyo SY-P4VDA-2AA2
May 16, 2008 | Soyo SY-P4VDA Motherboard
Soyo SY-7VBA133 Motherboard Logo
35 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
