Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Mahindra 3525 will not go in any gear
Started with the pto not engaging a week before
Mahindra 6110 2012 Cab Tractor. PTO will not engage even tho all lights come on as normal. Recently had clutch replaced. Any ideas?
Does it engage by an electrical switch or by a handle that you pull or push. If it is by a handle then make sure when they changed the clutch that they got all the linkages reconnected - if that is all there then there should be a sight cover to the pto clutch and make sure that the throwout bearing is in the proper location. If it engages by an electrical switch, make sure all the fuses are good and there is no connections left loose nor a harness or wire showing signs of being pinched or cut. An electrical switch activated PTO will have some kind of a motor somewhere that moves the clutch make sure that it is connected and it is also bolted up right and have somebody flip the switch and see if it's actually working - if motor hums momentarily or continously (parts missing).
Sep 15, 2017 | Garden
The pto grinds, and will not stay engaged on my Mahindra 475 DI. Is there a simple fix?
No you will need to pull it apart and see what is broken.
Jul 05, 2017 | Garden
Massey ferguson 135 pto keeps throwing out of gear drives but pto wont stay in gear why
possible that the teeth of the pto dog are worn to a taper and not fully engaged
the lever for the engagement is moving the full travel to engage
the bearings on the pto shaft are failing and allowing misalignment of the shaft thereby walking the dog out of engagement
Jan 05, 2017 | Toys
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
Mahindra tractor model 3525 diesel won't start need to check intake heater but i don't know where it is
The intake heater is located in the intake manifold. Should be a heavy wire going to it.
Jan 19, 2015 | Mahindra Cars & Trucks
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
My gears grind when i try and engage the pto
try engaging at a slower engine speed or engine off, if off engage then try, if grinding now take it apart and change worm and gear
Nov 25, 2013 | Troy-Bilt Pony Garden Tiller
PTO engages, but, keeps becoming disengaged on LT1042.
Cub Cadets have one of two types of PTOs. The most common is gear driven. The gear teeth of the PTO shaft are very small and thin. If the PTO is engaged without proper clutch action, the gear teeth grind together, trying to engage. A little wear on these gears will cause the surface of the gears to become beveled, and when the PTO comes under load, the beveled surfaces of the gear teeth force the gear lock to disengage. The only option is to replace the worn gears...
The second type of PTO drive is electric clutch. This is a disc type clutch that is engaged by energizing an electromagnet built into the clutch pack... any disruption of electrical power to the clutch pack while under load will cause the clutch to disengage and then possibly try to engage while under load and casues the clutch pack to slip and will overheat almost instantly...
Sep 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Apr 13, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
