Question about Seagate (CD72LWH-Q) Expansion Module
No pc boot when seagate expansion pluged - Seagate (CD72LWH-Q) Expansion Module
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: my computer wont startseagate
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Jun 05, 2012
Seagate expansion 1tb light is blinking and not showing up in my computer
plug the hard drive in different computer, if is not reconised is becose 1-is mecanical damage
2- virus corrupted
3- partition in diferrent OS (Apple)
Solution to fix:
1-boot the computer from a virus boot cd and scan all drives
2-if no important data on drive , go to errase drive and format with Acronics free software
3-try to plug in Apple system to test maybe will work
4- if detected by Apple partition and errase with that(easy to remove pc type boot viruses
5- if no options work trashed and buy new one $60.00
Jul 28, 2014 | Computers & Internet
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Seagate desktop expansion Xbox 360 hard drive format problem
Should work. Xbox uses FAT32, the same as Windows XP, Vista, 7 and 8 can all read it. When plugged into the computer can you see the disk in Disk Management?
Right Click Computer > Manage > Disk Mangement
Jan 29, 2013 | Seagate Computers & Internet
Seagate expansion portable drive won't post makes clicking noise
Very likely the head is no longer aligned, and can no read the disc correctly. This is physical damage that can not be repaired. There are specialist, but at premium prices.
Oct 20, 2012 | Seagate Expansion 500GB External USB 2.0...
How to use
Take unit and cords out of box.
Put cords in corresponding outlets.
Plug-in to electrical outlet.
Turn on PC and Hard-drive Unit.
Allow PC to boot drives. (A disc that was accompanied may need to be inserted into the PC for this step.)
Mar 31, 2011 | Seagate Expansion 1 TB USB 2.0 Portable...
I have a Seagate expansion external hard drive, i can connect it, but how do i use it-keep it simple
Put all your documents in my documents folder of your hard disk
or install the software come along with him CEEDO in the hard disk itself.
Always connect both the USP prot of the cale to the PC for better efficiency
Jan 15, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
My son downloaded a movie to my seagate expansion portable drive 250 gb. I pluged it into my computer and open My computer and I can find seagate. I click to open and I can see the file for the movie,...
Most likely you don't have the codec required for movies. You can try a different player, or you can install a codec pack such as The k-lite codec pack . It's free. All you need to do is to leave all the settings as is when you install it, and it should work afterwards. If it still doesn't then it's because Windows Media Player can't open it for some reason.
Another player would probably work in that case. I recommend trying Media Player Classic.
Dec 14, 2010 | Seagate Computers & Internet
WD pluged to a Seagate HD Media Player= no data??!!
whell th eproblem is, when u pluged it in to the seagate...... a variation of the first sector happend, or something like that, thats y you cannot access it frome vista, and propably frome xp 2, what u can do is , using special programes for fixing boot sectors **** they are for experienced users in that domain (ex of product, winpe mini cd....), or u can download any linux live cd, its totally free (google for it), i recomand puppy if you are not familior with linux, when u download the iso and burn it, plug your external drive and boot the cd, when loaded, mount the extrenal drive and the internal one (if u have one), you will see the data, copy them , and then reboot with windows and format the external drive...then recopy the files.
May 08, 2010 | Western Digital My Book Home Edition 500...
Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Nov 06, 2009 | Seagate Computers & Internet
Computers & Internet Logo
104 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
