At&t model CL4940 ( HowTo Set Up Answering System With Using Default) ??
I have worked with this At&t phone all day just to get the answering system to work with it's default System To Be Able For People To Be Able To Leave Messages So I Can Hear Them So I'm Able To Return The Calls.
SOURCE: GE 21091GE3 - A Answering System keeps Initializing What do I do?
Is the answer off ? Theres a button above where it tells you how many messages you have that turns the machine on & off. Ive hit it by accident and then people couldnt leave messages - the machine wouldnt even pick up. HOpe this helps....
Posted on Jun 27, 2007
SOURCE: ge speakerphone model 29897GE1-A
If you disconnect the battery and reconnect it disappears/ Not good.
Posted on Jun 04, 2008
SOURCE: help retun 4000 to default
Press menu and dial 8-9-3-7-6-2-0-0 to reset pin to 0000. If found this on another forum and it works - just tried it. Cheers.
Posted on Dec 01, 2008
SOURCE: RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Posted on Dec 03, 2008
cnavarro
  • 2460 Answers
SOURCE: Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Posted on Apr 23, 2010
How can I secsre a 'how to' manual for AT&T manual for CL4940 machine?
Most of the documentation for the CL4940 is available on the product page: https://telephones.att.com/pd/1889/CL4940-White-Corded-answering-system-with-backlit-display . Click on the Support & Manuals tab. The abridged manual is listed first; a quick start manual is also listed. You probably want the full user manual. The current direct link to the English version of this manual is https://cdn-media-att.vtp-media.com/products/CL/CL4940/CL4940_CIB_i15.0_20170524.pdf .
I hope this helps.
Dec 21, 2017 | Sewing Machines
Is it normal for my AT&T CL4940 phone's display to show the number of "missed calls" even though the phone's answering system is not on (because I use a separate answering machine to record calls)?
It's completely normal. The phone is simply saying it detected an incoming call that it didn't answer. Try setting your other answering machine to pick up immediately, perhaps that will stop your phone from "seeing" an incoming call.
Sep 27, 2017 | AT&T Lands Phones
My aswering machine won't allow people to leave a message
There are usually two reasons for this if the machine is on. 1) The memory is full. In that case, delete some messages. 2) The unit is set to Announce Only. This may be the default if you haven't set a personal greeting.
Please add a comment with the model of your machine for additional information on how to change the incoming message options.
(Make sure that your phone/phone line are receiving calls. (Check for dial tone, try calling the number).)
For some older phones and answering systems, the Announce/Number of Rings before picking up was set by a switch on the back or the side of the base. Most newer phones let you set this in the Menu. Try under General Settings > Answering System or an Answering System menu item. (Again without knowing the model, I can't be absolutely sure of the menu and sub-menu lists.)
I hope this helps.
(There are a lot of AT&T cordless phones that work at 5.8 GHz with answering systems. New models come out regularly.)
Dec 16, 2011 | AT&T Lands Phones
How to set answering machine to default setting
Since you declined to specify the model of your VTech system, I can only direct you to enter it into the search box here to download a copy of the manual.
Feb 13, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
Cl and 0 flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Dec 28, 2008 | Uniden Cordless Phone
Howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
Nov 29, 2007 | GE 29878GE1 Digital Answering Machine
Help! Re-recording message
Following are instructions for the GE25881 phone which is similar to your 25880. Hopefully this will work for you. -Vish Answering System Set Up This section shows you how to set up your answering system to receive incoming calls. Before you begin the setup, you must turn on the answering system. ? Press the conference/ans on/off button to turn the answering system on and off. NOTE: The display shows ANSWERER OFF when the answering system is off. The default status is on. Voice Instructions If you need additional assistance, press and hold the memo button on the base and follow the voice instructions. 12 Answering System Operation Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2 . Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep.
Jul 23, 2007 | GE 25880 Twin Phone
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
